STM32F4DISCOVERY Expansion Boards
  • STM32F4DISCOVERY Expansion Boards
Forum SD CARD READ ERROR
Join STM32F4DISCOVERY Expansion Boards to participate - click to join for free!
  • Replies 12 replies
  • Subscribers 7 subscribers
  • Views 2384 views
SD CARD READ ERROR
philip-1992
philip-1992 over 13 years ago
So I tweeked a bit with an example regarding SD card (2GB). Mainly I wish to load a message from a text file which is stored inside an SD card to be displayed on the touch screen in which later on hoepfully I would be able to use the same logic of this program to allow me to laod a bitmap image from SD CARD. However when I am running the program, the file is not read and it is not creating a new file either! is there something wrong with the logic of this program? As you can see I made a function that whenever there is a read or write error it goes to the fault_err() function in which the program terminates.
Any help regarding this issue would be greatly appreciated.
Thanks in advance below is my source code
/*Private Defines ------------------------------------------------------------*/
#define  LCD_BASE_Data               ((u32)(0x60000000|0x00100000))
#define  LCD_Data                    (*(vu16 *)LCD_BASE_Data)
/* Private variables ---------------------------------------------------------*/
SD_Error Status = SD_OK;
FATFS filesystem;              /* volume lable */
FRESULT ret;                        /* Result code */
FIL file;                        /* File object */
DIR dir;                        /* Directory object */
FILINFO fno;                        /* File information object */
UINT bw, br;
uint8_t buff[128];
/* Private function prototypes -----------------------------------------------*/
static void Delay(__IO uint32_t nCount);
static void fault_err (FRESULT rc);
void delay(__IO uint32_t nCount);
/*Main Function --------------------------------------------------------------*/
int main(void)
  uint8_t text [100];
  volatile uint32_t dlycnt;
  /* wait the power stable */
  for (dlycnt = 0; dlycnt < 10000000; dlycnt++);
  /* Initializes LCD */
  STM32f4_Discovery_LCD_Init();
  /* Clear the LCD */
  LCD_Clear(LCD_COLOR_WHITE);
  /* Set the LCD Text size */
  LCD_SetFont(&Font16x24);
   /* Clear the LCD */
  LCD_Clear(LCD_COLOR_BLACK);
  /* Set the LCD Back Color */
  LCD_SetBackColor(LCD_COLOR_BLACK);
  /* Set The LCD Text colour */
  LCD_SetTextColor(LCD_COLOR_WHITE);
  STM32f4_Discovery_Debug_Init();
  LCD_DisplayStringLine(LINE(2), "  Welcome");
  Delay(200);
  LCD_SetFont(&Font8x12);
  /* Initialize Debug uart available on Devkit407 board *******************/
  /* mount the filesystem */
  if (f_mount(0, &filesystem) != FR_OK) {
      LCD_DisplayStringLine (Line2, "  Could not open filesystem");
      Delay(200);
  Delay(10);
    LCD_DisplayStringLine (Line2, "  Open a test file");
    Delay(200);
  ret = f_open(&file, "message", FA_READ);
  if (ret) {
      LCD_DisplayStringLine (Line2, "  Not exist the test file");
      Delay(200);
  } else {
      LCD_DisplayStringLine (Line2, "  Type the file content");
      Delay(200);
    for (;;) {
      ret = f_read(&file, buff, sizeof(buff), &br);          /* Read a chunk of file */
      if (ret || !br) {
        break;                              /* Error or end of file */
      buff[br] = 0;
      sprintf((char*)text,"  %s",buff);//Display the Message
      LCD_DisplayStringLine(LINE(3), text);
      Delay(200);
    if (ret) {
      LCD_DisplayStringLine (Line2, "  Read the file error");
      Delay(200);
      fault_err(ret);
    LCD_DisplayStringLine (Line2,  "  Close the File");
    ret = f_close(&file);
    if (ret) {
      LCD_DisplayStringLine (Line2, "  Close the file error");
      Delay(200);
  /*  hello.txt write test*/
  Delay(50);
  LCD_DisplayStringLine (Line2, "  Create a new file");
  Delay(200);
  ret = f_open(&file, "HELLO.TXT", FA_WRITE | FA_CREATE_ALWAYS);
  if (ret)
    LCD_DisplayStringLine (Line2, "  Create a new file error");
    fault_err(ret);
  else
    LCD_DisplayStringLine (Line2, "  Write a text data. (hello.txt)");
    Delay(200);
    ret = f_write(&file, "Hello world!", 14, &bw);
    if (ret)
    LCD_DisplayStringLine (Line2, "  Write a text data to file error");
    Delay(200);
    else
      sprintf((char*)text,"  %u bytes written", bw);
      LCD_DisplayStringLine (Line2, text);
    Delay(50);
    LCD_DisplayStringLine (Line2, "  Close the file");
    Delay(200);
    if (ret)
      Delay(200);
  /*  hello.txt read test*/
  Delay(50);
  LCD_DisplayStringLine (Line2, "  Read the file");
  Delay(200);
  ret = f_open(&file, "HELLO.TXT", FA_READ);
  if (ret)
    LCD_DisplayStringLine (Line2, "  Open file error");
    Delay(200);
  else
    Delay(200);
    for (;;)
      if (ret || !br)
      buff[br] = 0;
      sprintf((char*)text,"%s",buff);
      Delay(200);
    if (ret)
      LCD_DisplayStringLine (Line2, "  Read File Error");
      Delay(200);
      fault_err(ret);
    Delay(200);
    if (ret)
      LCD_DisplayStringLine (Line2, "  Close file error");
      Delay(200);
  /* directory display test*/
  Delay(50);
  LCD_DisplayStringLine (Line2, "Open Root Directory");
  ret = f_opendir(&dir, "");
  if (ret)
    LCD_DisplayStringLine (Line2, "Open root directory error");
  } else
    LCD_DisplayStringLine (Line2, "Directory listing...");
    for (;;)
      ret = f_readdir(&dir, &fno);                    /* Read a directory item */
      if (ret || !fno.fname[0])
        break;          /* Error or end of dir */
      if (fno.fattrib & AM_DIR)
        sprintf((char*)text,"  <dir>  %s\n\r", fno.fname);
      else
        sprintf((char*)text,"%8lu  %s\n\r", fno.fsize, fno.fname);
    if (ret)
      LCD_DisplayStringLine (Line2, "Read a directory error");
      fault_err(ret);
  Delay(50);
  LCD_DisplayStringLine (Line2, "Test completed\n\r");
  /* Infinite loop */
  while (1)
   // STM_EVAL_LEDToggle(LED3);
    Delay(100);
* @brief   FatFs err dispose
* @param  None
* @retval None
  uint8_t text [100];
  const char *str =
                    "OK\0" "DISK_ERR\0" "INT_ERR\0" "NOT_READY\0" "NO_FILE\0" "NO_PATH\0"
                    "INVALID_NAME\0" "DENIED\0" "EXIST\0" "INVALID_OBJECT\0" "WRITE_PROTECTED\0"
                    "INVALID_DRIVE\0" "NOT_ENABLED\0" "NO_FILE_SYSTEM\0" "MKFS_ABORTED\0" "TIMEOUT\0"
                    "LOCKED\0" "NOT_ENOUGH_CORE\0" "TOO_MANY_OPEN_FILES\0";
  FRESULT i;
  for (i = (FRESULT)0; i != rc && *str; i++) {
    while (*str++) ;
  sprintf((char*)text,"  rc=%u FR_%s", (UINT)rc, str);
  Delay(200);
  //STM_EVAL_LEDOn(LED6);
  while(1);
  * @brief  Delay
  * @param  None
  * @retval None
  __IO uint32_t index = 0;
  for (index = (100000 * nCount); index != 0; index--);
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *         where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
void assert_failed(uint8_t* file, uint32_t line)
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* Infinite loop */
  while (1)
#endif
  • Kilohercas
    0 Kilohercas over 13 years ago
    Did you already tryed SD card with FATFS and it worked for you, since i know that is bug inside program, so you need to replace DISCOVERY_SDIO.c and .h files
  • philip-1992
    0 philip-1992 over 13 years ago in reply to Kilohercas
    Yes but the printf commands do not work. Nothing is displayed either on the monitor nor on the LCD. However when I entered an empty SD CARD, a new file with the text HELLO WORLD is created, therefore the example is working
  • Kilohercas
    0 Kilohercas over 13 years ago in reply to philip-1992
    It should be fprintf
  • philip-1992
    tried that before but it gives the following error: Error[Pe167]: argument of type "char *" is incompatible with parameter of type "struct __FILE *"
  • philip-1992
    0 philip-1992 over 13 years ago in reply to philip-1992
    If it helps the last thing that is shown on the screen when the program goes to the fault_err() function is : "rc = 1  FR_DISK_ERRe error"
  • philip-1992
    I have been doing some more debugging on this issues, and after the following commands;
      Delay(200);
      ret = f_open(&file, "message.txt", FA_READ);
    I added a watch on the variable ret which is resulting FR_DISK_ERR. is this error because incompatiblity issues with SD card? or because the SD is not initializing correctly? The sd card I am using is 2GB pq1
  • Kilohercas
    is it HC ? (SDHC)
    Better try below 1GB, like 512MB or 128MB
  • philip-1992
    Well it doesn't state that its SDHC. I will try to find a smaller SD card. Does the dev board has a limit to the size of SD card? Do you think that this is part of the problem? Because when I tried the example from ST, a text file was being created on the SD
  • zavovi
    0 zavovi over 13 years ago in reply to philip-1992
    Hi, I have the same problem. I'm using SDIO library with STM32F4 discovery kit and I programming webserver with SD card. If I use a demo project from element14 for read and write to SD card, it's ok. But if I use the same code in my project, it's problem.
    In line :   ret = f_open(&file, "message.txt", FA_READ); is error. Debugger is stopped here and nothing do. If I debog lower function, error is in checking SD card.
    Why in demo project is all ok but in my (the same functions) is error?
    Can you help me please?
  • philip-1992
    0 philip-1992 over 13 years ago in reply to zavovi
    Hi there,
    Your problem is very similar to mine. i did spend about 3 weeks to understand what was happening and apparantly there is some instances at which certain libraries work. Thus in order for your program to work, you need to save your project exactly at the same file where the examle is so that your program uses the same libraries just as the example. I gave you the solution that has worked for me. hope I was helpful... goodluck
