Technical Library
  • Technical Library
Technical Library
Documents Freescale: TWR-PXS3020-KIT Power Architecture PXS30 Functional Safety MCU Module
  • Author Author: atomar
  • Date Created: 23 Jul 2012 8:12 AM Date Created
  • Last Updated Last Updated: 18 Jan 2013 8:59 AM
  • Views 1031 views
Buy NowBuy NowDevelopment ToolsTechnical DocumentsVideoFeaturesKit Contents
Kit Overview
The Freescale's TWR-PXS3020-KITTWR-PXS3020-KIT module is part of the Freescale Tower System portfolio, a modular development platform that enables rapid prototyping and tool re-use through reconfigurable hardware. Elevate your design to the next level with this industrial power house by building your Tower System today.
The TWR-PXS3020-KITTWR-PXS3020-KIT microcontroller module can be used as a standalone single board computer (SBC) and as part of the Freescale Tower System rapid prototyping development platform. Choose from a variety of configurable hardware and software options to support your target application.
The PXS30, a SafeAssure solution, has dual core architecture and built-in hardware redundancy that makes it ideal for safety applications. Each core can run independently for increased performance. From low-level source code generation, to high-level operating system requirements, the PXS family is your industrial control solution.
The PXS30 devices are 32-bit Power ArchitectureRegistered embedded microcontrollers designed for safety critical applications. All devices in this family are built around a dual core safety architecture. The devices offer more processing power and larger memory sizes to handle a variety of industrial designs. The dual core can be operated in lockstep mode (redundant processing and calculations) or decoupled parallel mode (independent core operations). The PXS30 microcontrollers are SafeAssure solutions.
The PXS30 devices provide a cost-effective, single chip display solution for the industrial market. An integrated TFT driver with digital video input ability from an external video source, significant on-chip memory, and low power design methodologies provide flexibility and reliability in meeting display demands in rugged environments.
The advanced processor core offers high performance processing optimized for low power consumption, operating at speeds as high as 64 MHz. The family itself is fully scalable from 512 KB to 1 MB internal flash memory. The memory capacity can be further expanded via the on-chip QuadSPI serial flash controller module.
Key Applications: Safety Critical Applications , Consumer (Boiler Heating Control), Industrial (Programmable Logic Control (PLC), Input-Output Control (I/O Control), Off-Grid Solar Power Inverters, Commercial Solar Power Inverters, Residential Solar Power Inverters, Unmanned Vehicles (Ground, Air, Water), Motion Control, Process Control), Medical/Health Care (Anesthesia Unit Monitor, Ventilators and Respirators), Motor Control (Stepper Motor)
imageFreescale Development KitsimageFreescale Development Tools
Development Tools
Software Development Tools:
IDEFreescaleCodeWarriorAll Freescale MCU's
Freescale's software and development solutions take you beyond the silicon, helping to bring your embedded applications to life.  Learn More
RTOSFreescaleMQXColdFire / HC08 / HC12 / ARM / S08 / RS08 / PowerPC
The Freescale MQX Real-Time Operating System (RTOS) provides real-time performance within a small, configurable footprint. This RTOS is designed to allow you to configure and balance code size with performance requirements. Learn More
Back to top
Technical Documents
Learning Center
TypeDescription
User GuideFreescale: Quick Start Guide for TWR-PXS3020-KIT Tower Module
Product BriefFreescale: Product Brief for PXS30 Family Microcontroller
Product BriefFreescale: Product Brief for Functional Safety for Industrial Applications
DatasheetFreescale: PXS30 Microcontroller Data Sheet
Reference ManualFreescale: Reference Manual for PXS30 Microcontroller
Application NoteFreescale: Application Note for PXS30 Self Test Control Unit (STCU) Reset Configuration Data in Shadow Flash
Revision NoteFreescale: PXS30 Errata for Mask 0N72D
Design Elements
TypeDescription
Application LibraryFreescale: Software Code for PXS30 Self Test Control Unit (STCU) Reset Configuration Data in Shadow Flash
Back to top
Video
Video 1Video 2
This video is unavailable.
Back to top
Kit Features
  • High-performance 180 MHz e200z7d dual cores
  • Up to 2 MB flash memory with ECC
  • Up to 512 KB on-chip RAM ECC
  • Sphere of replication (SoR) for key components (such as core, eDMA, XBAR)
  • Redundancy checking units
  • SoR connected to a fault collection and control unit (FCCU)
  • Three PWM units with four 16-bit channels per module
  • Comunications interfaces:
    • 4 UART
    • 3 SPI
    • 4 CAN
    • 3 I²C
  • Ethernet
  • Up to four 12-bit analog-to-digital converters (ADCs)
  • Multi-port DDR DRAM Controller
Back to top
Kit Contents
The Freescale's TWR-PXS3020-KITTWR-PXS3020-KIT kit is supplied with the below contents:
  • TWR-PXS3020 board with a PXS30 32-bit Power ArchitectureRegistered MCU
  • USB cable
  • DVD with lab tutorials, software, training and collateral
  • Quick Start Guide document
  • TWR-SERTWR-SER - Tower System Serial Module
  • TWR-ELEVTWR-ELEV - Tower System Elevator Modules
Back to top
  • twr-pxs3020
  • twr-pxs30
  • freescale
  • 32-bit_power_architecture
  • twr-pxs3020-kit
  • twr-ser
  • pxs30
  • twr-elev
  • tower_system
