Technical Library
  • Technical Library
Technical Library
Documents Freescale: TWR-PXS2010-KIT Power Architecture PXS20 Functional Safety MCU Module
  • Author Author: atomar
  • Date Created: 23 Jul 2012 4:44 AM Date Created
  • Last Updated Last Updated: 18 Jan 2013 10:37 AM
  • Views 940 views
Buy NowBuy NowDevelopment ToolsTechnical DocumentsVideoFeaturesKit Contents
Kit Overview
The Freescale's TWR-PXS2010-KITTWR-PXS2010-KIT is a development board for the PXS20 family of 32-bit Power ArchitectureRegistered microcontrollers. It features the MPXS20VLQ120 device and targets industrial applications which require compliance with IEC 61508 (SIL 3) safety standard.
The TWR-PXS2010 operates as a standalone debug tool and can also be combined and used as part of the modular Tower System development platform.
The TWR-PXS2010-KITTWR-PXS2010-KIT module is part of the Freescale Tower System portfolio, a modular development platform that enables rapid prototyping and tool re-use through reconfigurable hardware. Elevate your design to the next level with this industrial power house by building your Tower System today.
The PXS20 series microcontrollers are system-on-chip devices that are built on Power Architecture technology and contain enhancements that improve the architecture’s fit in embedded applications, include additional instruction support for digital signal processing (DSP) and integrate technologies such as an enhanced time processor unit, enhanced queued analog-to-digital converter, Controller Area Network, and an enhanced modular input-output system.
The PXS20 family of 32-bit microcontrollers is the latest achievement in integrated safety controllers. The advanced and cost-efficient host processor core of the PXS20 family complies with the Power Architecture embedded category. It operates at speeds as high as 120 MHz and offers high-performance processing optimized for low power consumption. It capitalizes on the available development infrastructure of current Power Architecture devices and is supported with software drivers, operating systems and configuration code to assist with users’ implementations.
Key Applications: Industrial Control and Safety Applications
imageFreescale Development KitsimageFreescale Development Tools
Development Tools
Software Development Tools:
IDEFreescaleCodeWarriorAll Freescale MCU's
Freescale's software and development solutions take you beyond the silicon, helping to bring your embedded applications to life.  Learn More
RTOSFreescaleMQXColdFire / HC08 / HC12 / ARM / S08 / RS08 / PowerPC
The Freescale MQX Real-Time Operating System (RTOS) provides real-time performance within a small, configurable footprint. This RTOS is designed to allow you to configure and balance code size with performance requirements. Learn More
Back to top
Technical Documents
Learning Center
TypeDescription
User GuideFreescale: Quick Start Guide for TWR-PXS2010 Tower Module
Product BriefFreescale: Product Brief for PXS20 Microcontroller
DatasheetFreescale: PXS20 Microcontroller Data Sheet
Reference ManualFreescale: Reference Manual for TWR-PXS2010 Tower Module
Reference ManualFreescale: Reference Manual for PXS20 Microcontroller
Application NoteFreescale: Application Note for How to Use Boot Assist Module (BAM) on TWR-PXS20 Board
Application NoteFreescale: Application Note for PXS30 and PXS20 Safety Features
Application NoteFreescale: Application Note for Solar Panel 3-Phase Inverter Controlled by the PXS20
Design Elements
TypeDescription
Back to top
Video
Video 1Video 2Video 3
This video is unavailable.
Back to top
Kit Features
The Freescale's TWR-PXS2010-KITTWR-PXS2010-KIT Power architecture PXS20 functinal safety MCU module important features are as shown below:
  • Dual e200z4 CPU architecture
  • Dual processing spheres including: CPU, DMA, interrupt controller, crossbar and MPU for logic level fault detection
  • Two statically configurable modes of operation:
    • Lockstep operation (redundant processing and calculations)
    • Dual parallel mode (independent core operation
  • Fault collection unit, which monitors and manages fault events
  • Error correction coding on RAM and flash memory allows detection/correction of memory errors
  • Designed to address safety requirements outlined in IEC 61508 (SIL3)
  • A SafeAssure Solution
Back to top
Kit Contents
The Freescale's TWR-PXS2010-KITTWR-PXS2010-KIT is supplied with the below contents:
  • TWR-PXS2010 board with a PXS20 32-bit Power ArchitectureRegistered MCU
  • USB cable
  • DVD with lab tutorials, software, training and collateral
  • Quick Start Guide document
  • TWR-SERTWR-SER - Tower System Serial Module
  • TWR-ELEVTWR-ELEV - Tower System Elevator Modules
Back to top
  • pxs20
  • freescale
  • 32-bit_power_architecture
  • twr-ser
  • twr-pxs2010-kit
  • twr-elev
  • mpxs20vlq120
  • twr-pxs2010
  • tower_system
