Technical Library
  • Technical Library
Technical Library
Documents Texas Instruments: TPS63020EVM-487 Evaluation Module for TPS63020 Buck-Boost Converter
  • Author Author: atomar
  • Date Created: 18 Oct 2012 10:09 AM Date Created
  • Last Updated Last Updated: 25 Jun 2014 12:52 AM
  • Views 4096 views
BUY NOWBUY NOWTechnical DocumentsVideoFeaturesKit Contents
Kit Overview
The TPS63020EVM-487TPS63020EVM-487 evaluation module is a fully assembled and tested circuit for evaluating the TPS63020TPS63020 Buck-Boost Converter with 4A Switch. The TPS63020EVM-487 operates from a 1.8V to 5.5V supply and provides a 3.3V output.The EVM is designed to help the user easily evaluate and test the operation and functionality of the TPS63020.
The TPS6302x devices provide a power supply solution for products powered by either a two-cell or three-cell alkaline, NiCd or NiMH battery, or a one-cell Li-Ion or Li-polymer battery. Output currents can go as high as 3A while using a single-cell Li-Ion or Li-Polymer Battery, and discharge it down to 2.5V or lower.
The buck-boost converter is based on a fixed frequency, pulse-width-modulation (PWM) controller using synchronous rectification to obtain maximum efficiency. At low load currents, the converter enters Power Save mode to maintain high efficiency over a wide load current range. The Power Save mode can be disabled, forcing the converter to operate at a fixed switching frequency.
The maximum average current in the switches is limited to a typical value of 4A. The output voltage is programmable using an external resistor divider, or is fixed internally on the chip. The converter can be disabled to minimize battery drain. During shutdown, the load is disconnected from the battery. The device is packaged in a 14-pin QFN PowerPAD package measuring 3 × 4 mm (DSJ).
Key Applications: All Two-Cell and Three-Cell Alkaline, NiCd or NiMH or Single-Cell Li Battery Powered Products, Ultra Mobile PC's and Mobile Internet Devices, Digital Media Players, DSC's and Camcorders, Cellular Phones and Smartphones, Personal Medical Products, Industrial Metering Equipment, High Power LED's.
imageDevelopment KitsimageDevelopment Tools
Technical Documents
Learning Center
TypeDescription
User GuideTI: User Guide for TPS63020EVM-487 Evaluation Module
DatasheetTI: Datasheet for HIGH EFFICIENCY SINGLE INDUCTOR BUCK-BOOST CONVERTER WITH 4-A SWITCHES (Rev. B)
Selection GuideTI: Selection Guide for TI Solutions for Tablets and eBooks
Solution GuideTI: Solution Guide for Point-of-Load (POL) Power Point-of-Load (POL) Power
Application NoteTI: Application Note for Different Methods to Drive LEDs Using TPS63xxx Buck-Boost Converters (Rev. B)
Application NoteTI: Application Note for Design Calculations for Buck-Boost Converters (Rev. A)
Application NoteTI: Application Note for Design considerations for a resistive feedback divider in a DC/DC converter
Design Elements
TypeDescription
LayoutTI: Layout File for TPS63020
Reference DesignTI: Reference Design for TPS63020 TINA-TI Transient
Simulation ModelTI: SPICE Model for TPS63020 Transient
Simulation ModelTI: SPICE Model for TPS63020 TINA-TI Transient
Back to top
Video
Video1Video2
Back to top
Kit Features
productLinkproductLink Features:
  • Input Voltage Range: 1.8V to 5.5V
  • Adjustable Vout: 1.2V to 5.5V
  • Switch current rating 4A
  • Dynamic switch current limit
  • Efficiency: >93% over wide Vin range (max)
  • Package: 14-pin QFN , 3mm x 4 mm x 1 mm
  • Operating frequency: 2.4MHz, synchronizable (±20%)
  • Automatic transition between Step Down and Boost Mode
  • Very low typical quiescent current (<50µA)
  • Power Save Mode for improved efficiency at light loads
  • Over-temperature protection
TPS63020TPS63020 Features:
  • 3A Output Current at 3.3V in Step Down Mode (VIN = 3.6V to 5.5V)
  • More than 2A Output Current at 3.3V in Boost Mode (VIN > 2.5V)
  • Smart Power Good Output
  • Load Disconnect During Shutdown
  • Overvoltage Protection
Back to top
Kit Contents
The Texas Instruments TPS63020EVM-487TPS63020EVM-487 Evaluation Module supplied with below contents:
  • TPS63020EVM-487TPS63020EVM-487 Evaluation Module
Back to top
  • tps63020
  • tps63020evm
  • evaluation_module
  • texas_instruments
  • tps6302x
  • tps63020evm-487
