Technical Library
  • Technical Library
Technical Library
Documents Texas Instruments: MSP-TS430PW14 MSP430 14-Pin Target Board
  • Author Author: atomar
  • Date Created: 15 Nov 2012 11:33 AM Date Created
  • Last Updated Last Updated: 25 Jun 2014 12:52 AM
  • Views 1551 views
BUY NOWBUY NOWDevelopment  ToolsTechnical DocumentsVideoFeaturesKit Contents
Kit Overview
The Texas Instruments MSP-TS430PW14MSP-TS430PW14 is a standalone ZIF socket target board used to program and debug the MSP430 in-system through the JTAG interface or the Spy Bi-Wire (2-wire JTAG) protocol. The development board supports some MSP430 Flash parts in a 14-pin TSSOP package (TI package code: PW). Please check your target's device documentation to find the correct target board.
A separate debugging and programming interface is required to work with the MSP-TS430PW14MSP-TS430PW14. A flash emulation tool (FET) may be purchased independently (MSP-FET430UIF) or bundled with the MSP-TS430PW14 (MSP-FET430U14).
MSP430 Microcontrollers (MCUs) from Texas Instruments (TI) are 16-bit, RISC-based, mixed-signal processors designed specifically for ultra-low-power. MSP430 MCUs have the right mix of intelligent peripherals, ease-of-use, low cost and lowest power consumption for thousands of applications.
Key Applications: To program and debug the MSP430 (MCU provide wide range of low power and portable applications) in-system through the JTAG interface or the Spy Bi-Wire (2-wire JTAG) protocol.
imageTexas Instruments Analog Development KitsimageTexas Instruments Embedded Development Kits
Development Tools
Software Development Tools:
IDETexas InstrumentsCode Composer Studio (CCStudio)ALL TI MCUsCCStudio is an integrated development environment (IDE) for TI embedded   processor families. CCStudio comprises a suite of tools used to develop and debug embedded applications. It includes   compilers for each of TI's device families, source code editor, project build environment, debugger, profiler, simulators,   real-time operating system and many other features. Learn More
Hardware Development Tools:
EmulatorsTexas InstrumentsXDS100V2 JTAGXDS100V2 JTAGMSP430JTAG Emulator
Debugger / ProgrammerTexas InstrumentsMSP-FET430UIFMSP-FET430UIFMSP430MSP430 USB Debugging Interface
Debugger / ProgrammerTexas InstrumentsMSP-FET430PIFMSP-FET430PIFMSP430MSP430 Parallel Port Debugging Interface
Back to top
Technical Documents
Learning Center
TypeDescription
User GuideTI: User Guide for EM430F5137RF900 Dev Tool
User GuideTI: User Guide for Code Composer Studio v5.2 for MSP430
User GuideTI: User Guide for IAR Embedded Workbench Version 3+ for MSP430
DatasheetTI: Data Sheet for MSP430F20x1, MSP430F20x2, MSP430F20x3 - MIXED SIGNAL MICROCONTROLLER
WhitepaperTI: White Paper for Ultra-Low Power Comparison MSP430 vs. Microchip XLP Tech Brief
Revision NoteTI: Revision Note for MSP430F2001
Application NoteTI: Application Note for Migrating from the MSP430F2xx and MSP430G2xx Families to the MSP430FR58xx and MSP430FR59xx Family
Application NoteTI: Application Note for Migrating From the MSP430F2xx Family to the MSP430FR57xx Family
Application NoteTI: Application Note for MSP430 Capacitive Single-Touch Sensor Design Guide
Design Elements
TypeDescription
LayoutTI: Layout File for MSP-FET430U14 Development Board
BOMTI: BOM File for MSP-FET430U14 Development Board
Application LibraryTI: Software Code for MSP430 schematic symbols and footprints library for use with the Eagle CAD tool (Rev. E)
Application LibraryTI: MSP430F20x1, MSP430F20x2, MSP430F20x3 Code Examples (Rev. I)
Back to top
Video
Back to top
Kit Features
Key Features for MSP-TS430PW14MSP-TS430PW14 MSP430 14-Pin Target Board:
  • A separate debugging and programming interface is required to work with the MSP-TS430PW14.
  • A flash emulation tool (FET) may be purchased independently (MSP-FET430UIFMSP-FET430UIF) or bundled with the MSP-TS430PW14 (MSP-FET430U14MSP-FET430U14)
  • Standalone ZIF socket target board
  • Supports some MSP430 Flash parts in a 14-pin TSSOP package (TI package code: PW)
Back to top
Kit Contents
The Texas Instruments MSP-TS430PW14MSP-TS430PW14  Target Board is supplied with below contents:
  • Development board with 14-pin TSSOP (PW) ZIF socket (MSP-TS430PW14)
  • Two MSP430F2013IPWMSP430F2013IPW flash device
Back to top
  • msp-ts430pw14
  • msp430f2013ipw
  • texas_instruments
  • msp430
  • msp_ts430pw14
