Technical Library
  • Technical Library
Technical Library
Documents Cypress: CY8CKIT-003B PSoC®︎ 3 FirstTouch™︎ Starter Kit
  • Author Author: atomar
  • Date Created: 20 May 2013 5:57 AM Date Created
  • Last Updated Last Updated: 11 Feb 2014 2:56 AM
  • Views 1361 views
BUY NOWBUY NOWDevelopment ToolsTechnical DocumentsVideoFeaturesKit Contents
Overview
The CY8CKIT-003CY8CKIT-003 PSoCRegistered 3 FirstTouchTm Starter Kit is designed to get you acquainted with Cypress’s PSoC programmable system-on-chip design methodology and architecture.
This kit is designed to introduce you to the PSoC programmable system-on-chip design methodology and Cypress's new PSoC 3 architecture. This full-featured starter kit ships with an array of sensors, I/Os, projects, and software to quickly get you up to speed with PSoC CreatorTm and our powerful design methodology so you can easily evaluate PSoC and see what values the solution can provide.
This full-featured starter kit ships with an array of sensors, I/O’s, projects, and software to allow you to evaluate PSoC and see what values the solution can provide you. And, in addition to trying out PSoC 3, gain full access to other features of the FirstTouch Starter Kit like Serial Wire Debugging (SWD), an Accelerometer, a Thermistor, Proximity Sensing, a CapSenseRegistered touch-sensing interface, a 12-pin wireless module header, and even 28 general purpose I/O pins (GPIOs). Whatever your need for PSoC may be, the PSoC 3 FirstTouch Starter Kit has the tools to get you started – and hooked – on PSoC.
Key Applications: Consumer, Industrial and Medical Applications
imageMore Cypress Development KitsimageCypress Overview
imageKnode Development Kits & Platform Roomimageelement14 Knode
Development Tools
Software Development Tools:
Tool   TypeSupplierMPNSupported   FamilyDescription
IDECypressPSoC CreateorPSoC 3 / PSoC 4 / PSoC 5 / PSoC 5LP
PSoCRegistered CreatorTm is a state-of-the-art software development IDE combined with a revolutionary graphical design editor to form a uniquely powerful hardware/software co-design environment. This co-design approach frees embedded designers from hardware re-spins and software hacks. It also enables immediate testing of new ideas, rapid response to hardware changes, and error-free software interaction with on-chip peripherals.  Learn More
Programmer SoftwareCypressPSoC ProgrammerAll PSoC
The PSoC Programmer software tool supports all Cypress PSoC programming hardware and PSoC devices. PSoC Programmer is a simple GUI that connects to programming hardware to program and configure PSoC devices. From the GUI users will be able to select the target device, configure programming selections and execute a number of programming actions such as Program, Read, Verify and Erase. PSoC Programmer is a required installation for both PSoC Creator and PSoC Designer.
IDEARMKeil C51All 8051 CoreThe Keil C51 development tools for the 8051 Microcontroller Architecture support every level of software developer from the professional applications engineer to the student just learning about embedded software development. Learn More
Hardware Development Tools:
Emulator / Debugger / ProgrammerCypressCY8CKIT-002CY8CKIT-002PSoC 1 / PSoC 3 / PSoC 5MiniProg3 Program and Debug Kit is an all-in-one programmer for PSoC 1, PSoC 3 and PSoC 5 architectures and debug tool for PSoC 3 and PSoC 5 architectures
Emulator / Debugger / ProgrammerARMULINK2ULINK2All 8051 CoreULINK2 Debug Adapter
Back to top
Technical Documents
Learning Center
TypeDescription
User GuideCypress: Quick Start Guide for CY8CKIT-003 PSoC 3 FirstTouch Starter Kit
User GuideCypress: User Guide for CY8CKIT-003 PSoC 3 FirstTouch Starter Kit
Product BriefCypress: Product brief for CY8CKIT-003 PSoC 3 FirstTouch Starter Kit
DatasheetCypress: Datasheet for CY8C38 (PSoC 3) family
Application NoteCypress: Application Note (AN54181) for Getting started with a PSoC 3 design project
Application NoteCypress: AN61290 - Hardware Starting Guide for PSoC 3 and PSoC 5 Family
Design Elements
TypeDescription
BOMCypress: BOM for CY8CKIT-003 PSoC 3 Board Design Files
LayoutCypress: Layout for CY8CKIT-003 PSoC 3 Board Design Files
SchematicsCypress: Schematic for CY8CKIT-003 PSoC 3 Board Design Files
Application LibraryCypress: Software coding on CY8CKIT-003 PSoC 3 FirstTouch Starter Kit
Back to top
Video
Video 1Video 2
This video is unavailable.
Back to top
Kit Features
The CY8CKIT-003CY8CKIT-003 development kit features the following:
  • PSoC Creator development software with an integrated, free-edition Keil C51 Compiler
  • USB-based serial wire debugging (SWD) protocol programmer and debug interface
  • Accelerometer analog sensor
  • Thermistor analog sensor
  • Proximity analog sensor
  • CapSenseRegistered analog touch-sensing interface
  • 28-pin general purpose I/O pins
  • 12-pin wireless module header
Key Features of PSoC 3:
  • Single cycle 8051 CPU
  • Low voltage, ultra low-power
  • Versatile I/O system
  • Digital peripherals
  • Analog peripherals (1.71 V ≤ VDDA ≤ 5.5 V)
  • Programming, debug, and trace
  • Precision, programmable clocking
Back to top
Kit Contents
The Cypress CY8CKIT-003BCY8CKIT-003B kit is supplied with below contents:
  • PSoC 3 FirstTouch Board
  • USB A to mini B cable
  • 9V Battery
  • Proximity Wire (for use as a Proximity Detection Antenna)
  • Quick Start Guide
  • Kit CD, which includes: PSoC CreatorTm, Kit Projects, and Documentation
Back to top
  • cy8ckit-003b
  • psoc_3
  • cy8ckit-003
  • cypress
