Technical Library
  • Technical Library
Technical Library
Documents Cypress: PSoC®︎ 5 / 5L System-on-Chip Overview
  • Author Author: Yiying
  • Date Created: 31 May 2013 3:03 AM Date Created
  • Last Updated Last Updated: 12 Feb 2014 5:50 AM
  • Views 2756 views
Kits & Evaluation ModulesKey FeaturesDevelopment ToolsVideoTechnical Documents
Overview
PSoCRegistered 5 is a true programmable embedded system-on-chip integrating configurable analog and digital peripheral functions, memory and a microcontroller on a single chip. PSoC 5 architecture based PSoCRegistered 5LP adds  the power of the ARMR Cortex.-M3 processor running up to 67 MHz at 83.75 DMIPS. An industry standard, the Cortex-M3 processor leverages the ARM ThumbR-2 instruction set architecture and is ideal for migrating 8- and 16-bit applications to the 32-bit world. You can now run the latest audio algorithms, as well as basic video processing. Even complex motor control algorithms requiring fast signal processing such as field-oriented control (FOC), high.performance waveform generation for brushless motors and high-performance sensor applications, are no problem.
The PSoC 5 / 5LP family extends the world's only programmable embedded system design platform, shattering your design limitations. Take advantage of high-precision programmable analog including 12- to 20-bit delta-sigma ADCs, a digital logic library with dozens of drop-in peripherals, best-in-class power management and rich connectivity resources. Implement your 8-, 16-, or 32-bit designs with the high-performance ARM Cortex-M3 processors. PSoC 5 / 5LP architecture includes high-precision, programmable analog resources that can be configured as ADCs, DACs, TIAs, Mixers, PGAs, OpAmps, and more. It also includes enhanced programmable-logic based digital resources that can be configured as 8-, 16-, 24- and 32-bit Timers, Counters, and PWMs, as well as more advanced digital peripherals such as Cyclic Redundancy Check (CRC), Pseudo Random Sequence (PRS) generators, and Quadrature decoders. Designers have a unique ability to customize this digital system through full featured general purpose PLD-based logic available in PSoC 5 /5LP.
More Resources
imageCypress Development KitsimageCypress PSoC Creator IDE
imageKnode Development Kits & Platform Roomimageelement14 Knode
Key Features
The core features of the PSoC 5 devices are below:
  • ARM Cortex-M3 Processor
    • Up to 67MHz @ 83.75 DMIPS
    • Up to 256 KB of flash, 64 KB of RAM, and 2 KB EEPROM
  • Unmatched precision analog integration
    • Best-in-class ADCs
    • 2x12-bit 1Msps SAR ADCs
    • 20-bit DelSig ADC
    • 1.024V ±0.1% on-chip reference
    • Precision Analog
    • OpAmps, Comparators, I/VDACs, CapSenseRegistered, and more
    • Fully functional analog from 1.71 – 5.5V
  • The most flexible low power PSoC
    • 0.5V start-up Boost
    • 300nA low leakage Hibernate
    • Widest operating range 0.5V to 5.5V
  • 80+ production-ready components
    • CapSenseRegistered touch sensing
    • Segment LCD display
    • Trans-impedance amplifier
Back to top
Development Tools
Software Development Tools:
Tool  TypeSupplierMPNSupported  FamilyDescription
IDECypressPSoC CreateorPSoC 3 / PSoC 4 / PSoC 5 / PSoC 5LP
PSoCRegistered CreatorTm is a state-of-the-art software development IDE combined with a revolutionary graphical design editor to form a uniquely powerful hardware/software co-design environment. This co-design approach frees embedded designers from hardware re-spins and software hacks. It also enables immediate testing of new ideas, rapid response to hardware changes, and error-free software interaction with on-chip peripherals.  Learn More
Programmer SoftwareCypressPSoC ProgrammerAll PSoC
The PSoC Programmer software tool supports all Cypress PSoC programming hardware and PSoC devices. PSoC Programmer is a simple GUI that connects to programming hardware to program and configure PSoC devices. From the GUI users will be able to select the target device, configure programming selections and execute a number of programming actions such as Program, Read, Verify and Erase. PSoC Programmer is a required installation for both PSoC Creator and PSoC Designer.
IDEARMKeil MDK-ARMARM CortexTm-M  / Cortex-R4 / ARM7Tm / ARM9TmThe MDK-ARM is a complete software development environment for CortexTm-M, Cortex-R4, ARM7Tm and  ARM9Tm processor-based devices. MDK-ARM is specifically designed for microcontroller applications, it is easy to learn  and use, yet powerful enough for the most demanding embedded applications.Learn  More
RTOSSeggerembOSARM CortexTm-MembOS is a priority-controlled real time operating system, designed to be used as foundation for the development of  embedded real-time applications. It is a zero interrupt latency, high-performance RTOS that has been optimized for  minimum memory consumption in both RAM and ROM, as well as high speed and versatility.  Learn More
Hardware Development Tools:
Emulator / Debugger / ProgrammerCypressCY8CKIT-002CY8CKIT-002PSoC 1 / PSoC 3 / PSoC 5MiniProg3 Program and Debug Kit is an all-in-one programmer for PSoC 1, PSoC 3 and PSoC 5 architectures and debug tool for PSoC 3 and PSoC 5 architectures
Emulator / Debugger / ProgrammerARMULINK2ULINK2ARM CortexTm-M  / ARM7Tm / ARM9TmULINK2 Debug Adapter
Emulator / Debugger / ProgrammerARMULINKProULINKProARM CortexTm-M  / ARM7Tm / ARM9TmULINKpro Debug and Trace Unit
EmulatorSeggerJ-LinkJ-LinkARM CortexTm-M  / Cortex-R4 / Cortex-A / ARM7Tm / ARM9TmJTAG/SWD Emulator with USB interface
ProgrammerSeggerFlasher ARMFlasher ARMARM CortexTm-M  / Cortex-R4 / Cortex-A / ARM7Tm / ARM9TmFlash Programmer for ARM and Cortex cores
Back to top
Video
This video is unavailable.
Back to top
Technical Documents
Learning Center
TypeDescription
Product BrochureCypress: Product Brochure for PSoC Programmable System-on-Chip
Back to top
  • psoc5
  • psoc_5
  • psoc_5lp
  • psoc5lp
