Technical Library
  • Technical Library
Technical Library
Documents Analog Devices: EVAL-AD5541ASDZ Evaluation Board for the AD5541A Serial-Input, Voltage-Output 16-bit nanoDAC
  • Author Author: atomar
  • Date Created: 27 Mar 2013 4:29 AM Date Created
  • Last Updated Last Updated: 23 Apr 2013 3:42 AM
  • Views 1021 views
BUY NOWBUY NOWDevelopment ToolsTechnical DocumentsVideoFeaturesKit Contents
Kit Overview
The EVAL-AD5541ASDZEVAL-AD5541ASDZ is the evaluation board to evaluate AD5541AAD5541A. The Evaluation board contains a SDP-B connection and software allowing the AD5541A to be controlled from a SDP-B system development platform board (EVAL-SDP-CB1ZEVAL-SDP-CB1Z) should be purchased separately. The Eval-AD5541ASDZ board only operates with the SDP-B development board.
The AD5541AAD5541A is a single, 16-bit, serial input, unbuffered voltage output digital-to-analog converter (DAC) that operates from a single 2.7 V to 5.5 V supply. The DAC output range extends from 0 V to VREF and is guaranteed monotonic, providing ±1 LSB INL accuracy at 16 bits without adjustment over the full specified temperature range.
Offering unbuffered outputs, the AD5541AAD5541A achieves a 1 μs set-tling time with low power consumption and low offset errors. Providing low noise performance of 11.8 nV/√Hz and low glitch, the AD5541A is suitable for deployment across multiple end systems. The AD5541A uses a versatile 3-wire interface that is compatible with a 50 MHz SPI, QSPITm, MICROWIRETm, and DSP interface standards.
Key Applications: Automatic test equipment, Precision source-measure instruments, Data acquisition systems, Medical instrumentation, Aerospace instrumentation, Communications infrastructure equipment, Industrial control
imageMore Analog Devices Analog Development KitsimageAnalog Devices MCU based Development Kits
Development Tools
SDP-B System Development Platform EVAL-SDP-CB1ZEVAL-SDP-CB1Z Features:
  • Blackfin Processor ADSP-BF527
  • USB 2.0 Interface to PC
  • JTAG header footprint
  • 32MB SDRAM
  • 2 x Small Footprint 120 Pin Connectors
  • Configurable Peripheral Interfaces - SPI - SPORT - I2C - GPIOs - Parallel - Timers
Back to top
Technical Documents
Learning Center
TypeDescription
DatasheetADI: Datasheet for AD5541A: 2.7 V to 5.5 V, Serial-Input, Voltage- Output, Unbuffered 16-Bit DAC (Rev A)
Product BriefADI: Product Brief for Programmable Current and Voltage Output Drivers
Solution GuideADI: Solution Guide for Digital-to-Analog Converter ICs Solutions Bulletin (Volume 10, Issue 1)
Solution GuideADI: Solution Guide for Digital to Analog Converters ICs
Design Elements
TypeDescription
Application LibraryADI: Application Library for BeMicro FPGA Project for AD5541A with Nios driver
Application LibraryADI: Software Code for AD5541A - No-OS Driver for Renesas Microcontroller Platforms
Application LibraryADI: Software Code for AD5541A - No-OS Driver for Microchip Microcontroller Platforms
Reference DesignADI: Reference Design for AD5541A FMC-SDP Interposer and Evaluation Board / Xilinx KC705
Reference DesignADI: Reference Design for AD5541A Pmod Xilinx FPGA
CAD ModelADI: CAD Model for AD5541Axx
Back to top
Video
Back to top
Kit Features
Features of EVAL-AD5541ASDZEVAL-AD5541ASDZ Evaluation Board:image
  • EVAL-AD5541ASDZEVAL-AD5541ASDZ evaluation board evaluates AD5541AAD5541A nanoDAC
    • 16-bit resolution
    • 11.8 nV/√Hz noise spectral density
    • 1 μs settling time
    • 1.1 nV-sec glitch energy
    • 0.05 ppm/°C temperature drift
    • 5 kV HBM ESD classification
    • 0.375 mW power consumption at 3 V
    • 2.7 V to 5.5 V single-supply operation
    • Hardware CS and LDAC functions
    • 50 MHz SPI-/QSPI-/MICROWIRE-/DSP-compatible interface
    • Power-on reset clears DAC output to zero scale
  • Evaluation board contains a SDP-B connection and software allowing the AD5541A to be controlled from a SDP-B board
  • AD5541A uses a versatile 3-wire interface that is compatible with a 50 MHz SPI, QSPITm, MICROWIRETm, and DSP interface standards.
Back to top
Kit Contents
The Analog Devices EVAL-AD5541ASDZEVAL-AD5541ASDZ supplied with below contents:
  • EVAL-AD5541ASDZEVAL-AD5541ASDZ Evaluation board
Back to top
  • eval-ad5541asdz
  • ad5541a
  • sdp-b
  • nanodac
  • analog_devices
