Technical Library
  • Technical Library
Technical Library
Documents Gertboard: Application Library for Gertboard Kit (Linux)
  • Author Author: atomar
  • Date Created: 8 Aug 2012 2:10 PM Date Created
  • Last Updated Last Updated: 8 Oct 2021 6:24 AM
  • Views 2621 views
  • Comments 14 comments
Application Library for Gertboard Kit (Linux), contains test/example programs written in C.
gertboard_sw_20120725.zip
  • gertboard
  • linux
  • Application Library
    e14 Contributor over 14 years ago +2
    I couldn't help but snigger when I read the comment in the common header header file "Try to strike a balance between keep code simple for novice programmers but still have reasonable quality code". Forgive…
    e14 Contributor over 14 years ago +1
    Umm.. For a complete novice, this file is garble. I don't understand any of it. I understand these files contain C code to perform some function on the Gertboard but there's no simple explanation to what…
  • fustini
    fustini over 13 years ago
    fyi: current software for GertBoard: http://www.element14.com/community/docs/DOC-52909/l/assembled-gertboard-software-jan-2013
  • fustini
    fustini over 13 years ago in reply to e14 Contributor
    hi - this is the latest software download: http://www.element14.com/community/docs/DOC-52909/l/assembled-gertboard-software-jan-2013.  also, the command would be "unzip <name of zip file>".  I see you wrote "zip gertboard_20120725"
    I have downloaded 38-101479,
    next I renamed it:    mv 38-101479   gertboard_20120725.zip
    next  I did the ls -A comand and I found gertboard_20120725.zip
    next I did a command:    zip gertboard_20120725.zip, I did not work
    I am using Occidentalis_v02.img, How can find out if has a zip program?
    Edit: I just realised it was the newer gertboard_sw_20130106.zip I grabbed from http://www.element14.com/community/docs/DOC-52909/l/assembled-gertboard-software-jan-2013?ICID=gertboard-techdoc
    Ignore this comment.
  • joaquinquin
    joaquinquin over 13 years ago in reply to captainofspray
    just download it. you get a file named '38-101479'.  This is a zip file. you can rename it to 'something.zip' and unzip it
  • captainofspray
    captainofspray over 13 years ago
    Wanted to download this direct to the Pi, but Midori does not understand how this indirect link works - it downloads some unreadable text, but not the zip file.
    I'm going to have to find some other way to get the library onto the Pi.
    I couldn't help but snigger when I read the comment in the common header header file "Try to strike a balance between keep code simple for novice programmers but still have reasonable quality code". Forgive my cynicism, but here we have an example of PURE geeksville - the usual C++ cacophony of angle brackets, ampersands and curly braces without a letter (let alone a word) of commentary. How does this sit with the RPi foundation's objective of making the RPi a platform for teaching programming to the next generation? It's entirely appropriate, therefore, that I paid nothing for it - thank goodness! Sorry - I usually express gratitude for the free stuff that I grab from the web - so (please) think of this post as a wry comment rather than a vicious swipe.
    e14 Contributor over 14 years ago in reply to fustini
    Thanks Drew, yeah I read that as well, and was wondering if someone had newer info....
    So, the question becomes, any 'guidelines' for using Python on the gertboard?  One of the considerations when I chose the Pi was its use of Python since it is realtively simple to learn and understand.  Particularly for students new to computing.
    thanks for any insight!
  • fustini
    fustini over 14 years ago in reply to e14 Contributor
    I was reading the Gertboard manual last night and it does state there are plans to do that.  I suspect there will also be various efforts from the community as well.
    Newbie question:
    Are there plans to develop a set of libraries to use python?
    Thanks!
