Autodesk EAGLE
Autodesk EAGLE
Blog Board Outline Helper
  • Author Author: ipv1
  • Date Created: 3 Apr 2017 6:00 PM Date Created
  • Views 1864 views
  • eagleulpcontest
  • eagleulp
ipv1
ipv1
3 Apr 2017
This is my submission for the EAGLE Workshop CadSoft EAGLE Design Competition EAGLE ULPs Contest at EAGLE Exchange
With the Autodesk takeover of Eagle, a lot of new features have been introduced which make ULPs for panelisation, parameter checking etc redundant. My submission for this contest is a rather simple one which makes up for it's lack of complexity with it usefulness and flexibility.
The Board Outline Helper
My ULP is a custom, hand-coded tool that is used to generate a board outline which may sound simple BUT when rounded corners are to be added, this little script comes in pretty handy. The idea is simple and draws out everything from straight cut edges to circular PCBs. This is one feature that is yet to be implemented in Eagle and the script help with the setup. Once executed, a dialog pops up and asks the user about the outline parameters
Sample
Filling up the appropriate values produces the desired results. e.g.
image image
OR
image image
Now rounded shapes are no longer a problem.
More use cases
The board helper can create shapes hence we can use it for slots and cutouts as well. Here is an example.
image image
In the future I intend to add some title blocks and logos in addition to a DXF importer but since those features are something I have not fully tested, I would like to submit this slim ULP for this challenge.
Thanking You,
Sincerely,
IP
About me: I am a part-time teacher and part-time PhD student at GNDU Amritsar. With over two decades of hands on experience, I am an engineer by passion and love making and sharing things. I write about projects in my blogs as well as have publications in books as well as guest articles. For more information about me, please visit:https://inderpreet.github.io
  • geralds
    geralds over 9 years ago +1
    Hi, this is a very nice tool. Yes, I like komplex PCBs. I mostly work with that board outlines, e.g. for DIN rail modules. Gerald ---
  • ipv1
    ipv1 over 9 years ago in reply to geralds
    I will add that in the next version. image
  • geralds
    Hi,
    Gerald
  • rachaelp
    rachaelp over 9 years ago
    Very nice! It's a really simple concept that implements something basic which EAGLE lacks. Will you be making this available to download at some point?
    Best Regards,
    Rachael
