Autodesk EAGLE
Autodesk EAGLE
Blog from board to library part
  • Author Author: matrixgti
  • Date Created: 29 Feb 2016 10:05 PM Date Created
  • Views 1400 views
matrixgti
matrixgti
29 Feb 2016
Hi All, this is my first post on this forum.
I have a question about a board that i just design, is basically a breakout board for an Atmel 2560 with pin header.
Now i have to embed this board into another board , is there a way to convert the board into a library componet without re-assign 100 pin in a new Package, Device etc ?
Thanks in advanced
Flavio
  • Richard_H
    Richard_H over 10 years ago
    You can't convert it into a library object. But you can import the design into another design with the File/Import/EAGLE drawing option.  Hope this helps.
    -Richard
    BTW: The blog area is not the correct place to post technical support questions. Please check the forum section  Forums
