Autodesk EAGLE
Autodesk EAGLE
Blog LibIt.ulp make creating packages more easier (Eagle Contest Entry)
  • Author Author: yahyatawil
  • Date Created: 31 Mar 2017 1:30 PM Date Created
  • Views 1645 views
  • eagle library
  • eagle ulp contest
  • eagle package
  • eagleulp
yahyatawil
yahyatawil
31 Mar 2017
LibIt ULP
This ULP makes creating packages for libraries much easier. You can use is to draw multiple SMDs/PADs, lines and rectangles
PAD Dialog has the following options:
  • Select Shape: Select the shape of pad (Square-Round-Octagon-Long-Offset).
  • Select Axis: Select the axis of pads. Adding them horizontally or vertically.
  • Select PAD Angle: Select the angle of pad (0-45-90-180).
  • Count of PADs: Select how many pads you want to add.
  • Pitch (Distance): Select the distance between every 2 pads.
  • Origin : Select X and Y of the origin.
SMD Dialog has the following options:
  • Select SMD Angle: Select the angle of SMD (0-45-90-180).
  • Count of SMDs: Select how many SMDs you want to add.
  • Roundness: Roundness of SMD.
  • Pitch (Distance): Select the distance between every 2 SMDs.
  • Size : Size of SMD (X & Y).
Line Dialog
  • Select Layer
  • Width: Select width of the wire.
  • Length: Select length of the wire.
Rectangle Dialog
  • Select Layer
  • Size: Select size of rectangle.
See how to use it in this video
LibIt.zip
