EAGLE Support (Deutsch) Farnell-Absenderadressen
  • Subscribers 189 subscribers
  • Views 924 views
Was bedeutet es, wenn in einer EAGLE-Newsgroup (gelesen ueber einen
Newsreader und NICHT per Browser) als Absenderadresse
   communitymanager@premierfarnell.com
erscheint?
Ich hatte urspruenglich gedacht, dies sei eine Gruppenadresse diverser
Farnell-Mitarbeiter, die sich u.a. ein wenig mit EAGLE beschaeftigen.
Durch den Inhalt diverser Nachrichten bin ich von dieser anscheinend
irrigen Meinung jedoch wieder abgekommen.
Andreas Weidner
    e14 Contributor over 15 years ago in reply to fustiniadmin
    Am 02.11.2011 00:04, schrieb Drew Fustini:
    However, I would agree with the suggestion that posts by Premier Farnell
    employees should have their individual corporate email address visible
    in NNTP From header.
    Yes, please.
    The From will also contain the display name of the
    user. For example, "John Smith <noreply-293146@element14.com>". This is
    a work in progress and suggestions are welcome.
    Yes, please.
    Both solutions sound extremely useful...
    Andreas Weidner
    in NNTP From header.  I'll bring this suggestion to our team.
    On a related note, I am working on a change so that the From address for
    all NTTP posts via element14 will be unique per user account.  If the
    element14 user has set their email to private, then the From address
    will be noreply-<element14-user-id>@element14.com.  This will correct
    the user profile conflicts which occur on the EAGLE Central Forums
    (eaglecentral.ca).  The From will also contain the display name of the
    is a work in progress and suggestions are welcome.
    Thanks for addressing this. If both changes are really applied, that
    will solve the problem perfectly.
    Tilmann
  • fustiniadmin
    fustiniadmin over 15 years ago in reply to e14 Contributor
    On 10/31/2011 04:49 AM, Andreas Weidner wrote:
    Am 30.10.2011 14:16, schrieb Tilmann Reh:
    >> Das ist ein klarer Fall von Mißkonfiguration. Den Benutzern hätte man
    >> anonymisierte Mailadressen (user12345@...) oder wenigstens eine von den
    >> Betreuern abweichende Sammeladresse (e14user@...) geben können/müssen.
    Ja, BITTE! Wenn schon keine RICHTIGE E-Mail-Adresse da steht, sollte man
    wenigstens erkennen koennen, wer ein Benutzer und wer ein Mitarbeiter
    ist...
    Andreas Weidner
    Hallo,
    Ich bin ein element14 Entwickler und Premier Farnell Mitarbeiter. Es tut
    mir leid, aber ich spreche kein Deutsch. Ich bemerkte, dass Subject und
    bin mit Google übersetzen. Entschuldigt, wenn meine Worte nicht
    übersetzen gut.
    Dank Tilman Reh zu erklären, warum communitymanager@premierfarnell.com
    in NNTP Beiträge, die auf unserer Website element14 CadSoft Foren
    stammen scheint. Die meisten Benutzer haben wählen
    Datenschutz-Einstellungen so, dass ihre E-Mail-Adresse nicht angezeigt
    wird. Daher hat die Aus-Header unsere allgemeinen Gemeinde-Mail-Adresse.
    Diese Adresse wird von unseren Mitarbeitern überwacht.
    Allerdings würde ich mit dem Vorschlag, dass Beiträge von Premier
    Farnell Mitarbeiter sollen ihre individuellen Corporate-Mail-Adresse
    sichtbar in NNTP From header einigen. Ich werde diese Anregung in unser
    Team bringen.
    Auf einem verwandten beachten, bin ich auf eine Änderung, so dass die
    Von-Adresse für alle NTTP Beiträge über element14 wird einzigartig pro
    Benutzerkonto arbeiten. Wenn der element14 Benutzer ihre E-Mail zu
    setzen private, dann die Absenderadresse noreply-<element14-user-id> @
    element14.com werden. Dies wird korrekt das Benutzerprofil Konflikte,
    die auf dem EAGLE Zentral-Forums (eaglecentral.ca) auftreten. Die Aus
    enthält auch den Anzeigenamen des Benutzers. Zum Beispiel, "John Smith
    <noreply-293146@element14.com>".  Dies ist ein work in progress und
    Anregungen sind willkommen.
    Danke,
    Drew Fustini
    element14
    I am an element14 developer and Premier Farnell employee.  I am sorry,
    but I don't speak German.  I noticed that Subject and am using Google
    translate.  Apologies if my words do not translate good.
    Thanks to Tilman Reh for explaining that why
    communitymanager@premierfarnell.com appears in NNTP posts that originate
    on our element14 website CadSoft forums.  Most users have select privacy
    settings so that their email address is not shown.  Therefore, the From
    header has our general community email address.  This address is
    monitored by our staff.
    Thank You,
    Drew Fustini
    element14
    wenigstens erkennen koennen, wer ein Benutzer und wer ein Mitarbeiter ist...
    Andreas Weidner
    erscheint?
    Diese Adresse wird anscheinend bei /allen/ element-14 Teilnehmern
    verwendet, die der Veröffentlichung ihrer echten Mailadresse nicht
    zugestimmt haben (und damit wohl bei den meisten).
    Diese Leute von Farnell haben anfangs ebenfalls diese Adresse verwendet
    (und tun es vermutlich auch heute noch).
    Tilmann
