EAGLE Support (Deutsch) (re)naming all pads of a package
  • Views 288 views
cloning a package is very fine. Also building a package as a composition of
several packages.
But having to rename about 100 pads or more is somehow a grunt job.
Especially if each pad needs 2 clicks to select it ...
What about a job, that calls the "name" function on every pad in the
package? I skimmed the ulp-section, but from the description I did not find
a match.
kind regards
Reinhard Mantey
  • kcadsoft
    kcadsoft over 18 years ago
    On 09/21/08 17:51, Reinhard Mantey wrote:
    several packages.
    a match.
    You can easily write a ULP for such a special function yourself.
    (wrong NG, f'up-to eagle.suggest.eng)
    Klaus Schmidinger
    Hofmark 2                               Email:   kls@cadsoft.de
