EAGLE Support (Deutsch) extended grid
  • Views 519 views
extended grid
another beautiful aid would be, having each n-th line bolded, i.e. each 2nd,
5th or 10th line, so that counting grid lines will be a bit easier.
Additionally I would like the possibility to put an offset to the grid, to
better check alignment of pads, dimensions of packages or so.
kind regards
Reinhard Mantey
    Joern Paschedag wrote:
    I use long crosshairs...;-)
    My hairs are not long enuf to cross themself image
    ... just kidding. Thx for the word!
    kind regards
    Reinhard Mantey
  • kcadsoft
    kcadsoft over 18 years ago
    On 09/21/08 17:56, Reinhard Mantey wrote:
    You can use the "multiple" parameter to have only the n-th line shown.
    You can use the MARK command to display relative coordinates.
    (wrong NG, f'up-to eagle.suggest.eng)
    Klaus Schmidinger
    Hofmark 2                               Email:   kls@cadsoft.de
    Reinhard Mantey schrieb:
    Did you try the multiplicator in the GRID Menue?
    kind regards
    Reinhard Mantey
    Gruß
    Jörn
