EAGLE Support (Deutsch) PCB designing vias control
  • Views 404 views
  • pcb
Hello Sir
I would like to know whether I can make a multilayer PCB with connections done through auto-route and also the vias are placed automatically. Also what I require is that the via placement could be controlled automatically, meaning no two vias should align side-by-side or no via of one layer is just below the via of other layer. Could I do something like this or I could control all this through some external program like C or MATLAB.
I would like to have the solution to this.
Thanking You
Regards
Sitank Bhatia
    Hello
    I read the following document but I was unable to gather the fact that whether I can do all the vias placement through the auto-route, keeping the requirement of placing the two vias at a certain angle and position from each other. Nothing of the above should require any manual handling.
    Thanking You
    Regards
    Sitank Bhatia
    Am 21.02.2014 10:24, schrieb Sitank Bhatia:
    Hello Sir
    Please read ..\doc\layer-setup_designrules.pdf
    Alfred Zaffran
                                 Web:   <www.cadsoft.de>
    EAGLE V6.5 availabe now!
