EAGLE Support (Deutsch) More detailed DRC error reporting
  • Subscribers 187 subscribers
  • Views 139 views
autodeskguest over 12 years ago
Currently, the DRC settings differentiate between same signal and
different signals, but the error report does not. This is unfortunate,
since same signal violations are often far less severe than different
signal violations. It would be great if eagle could generate a more
detailed report (e.g.
Clearance: Same signal (GND), Objects (Via, Trace), Layer 16
Clearance: Same signal (GND), Objects (Via, Pad), Layer 16
Clearance: Signals (GND, +5V), Objects (Via, IC 15 Pad), Layer 16
Overlap: Same signal (GND), Objects (Via, IC 15 Pad), Layer 16
Overlap: Signals (GND, +5V), Objects (Via, C 5 Pad), Layer 16@
etc.)
Especially with polygon pours it is often difficult to determine which
are the offending objects. This improvement would also allow to skip
multiple errors for different segments of the same trace and would
improve error handling.
Um alle Bilder und Anhänge in diesem Beitrag zu sehen, besuchen Sie:
http://www.element14.com/community/message/114991
