EAGLE Support (Deutsch) B82793S0513N201
  • Subscribers 189 subscribers
  • Views 885 views
B82793S0513N201
sahana
sahana over 9 years ago
I want a eagle library for  B82793S0513N201B82793S0513N201 Where can I find it
  • HannoKock
    0 HannoKock over 9 years ago in reply to HannoKock
    Am 03.02.2017 um 16:44 schrieb Hanno Kock:
    Am 07.12.2016 um 20:32 schrieb rachaelp:
    (https://www.element14.com/community/view-product.jspa?fsku=1644921&nsku=12P7397&COM=noscript)B82793S0513N201
    Where can I find it
    I was brought up with the saying "I want gets nothing". A please and
    thank you would help.
    It is a 4 pin part and all the information required to create the
    library part is very clearly specified in the datasheet. Just learn
    how to create your own parts and and dit it yourself, it's about a 2
    minute job to create that part once you know what you are doing.
    Best Regards,
    Rachael
    ACK
    Learning Eagle - easy job. You will have to make your own parts day by
    day...
    BTW - a very special part, current compensated signal line choke - you
    won't find that anywhere. Invest the time for searching in doing it by
    yourself. Advantage is you learn eagle.
    Kind regards
  • HannoKock
    0 HannoKock over 9 years ago in reply to rachaelp
    saha M S wrote:
    I want a eagle library for  (https://www.element14.com/community/view-product.jspa?fsku=1644921&nsku=12P7397&COM=noscript)B82793S0513N201 (https://www.element14.com/community/view-product.jspa?fsku=1644921&nsku=12P7397&COM=noscript)B82793S0513N201 Where can I find it
    I was brought up with the saying "I want gets nothing". A please and thank you would help.
    It is a 4 pin part and all the information required to create the library part is very clearly specified in the datasheet. Just learn how to create your own parts and and dit it yourself, it's about a 2 minute job to create that part once you know what you are doing.
    Best Regards,
    Rachael
    ACK
    day...
  • rachaelp
    0 rachaelp over 9 years ago
    saha M S wrote:
    I want a eagle library for B82793S0513N201B82793S0513N201B82793S0513N201 Where can I find it
    It is a 4 pin part and all the information required to create the library part is very clearly specified in the datasheet. Just learn how to create your own parts and and do it yourself, it's about a 2 minute job to create that part once you know what you are doing.
    Best Regards,
    Rachael
    0 autodeskguest over 9 years ago
    Where did you already search?
    Uwe Bonnes                bon@elektron.ikp.physik.tu-darmstadt.de
    Institut fuer Kernphysik  Schlossgartenstrasse 9  64289 Darmstadt
    Tel. 06151 1623569 -
    Fax. 06151 1623305 -
