EAGLE Support (Deutsch) Where are the Port Symbols?
  • Subscribers 187 subscribers
  • Views 691 views
today i received Eagle 5.2 (always used 4.xx)
when i had my schematic over multiple sheets i allways used the 'PORT2,
PORT3'  part (which could be found in the 'frames'-library) to indicate the
name of the net and to make clear it was used on a different sheet.
I don't see this anymore in this new version! Can anybody help me?
best regards,
Joop Tap
  • Richard_H
    Richard_H over 18 years ago
    Joop Tap schrieb:
    the name of the net and to make clear it was used on a different sheet.
    best regards,
    Joop Tap
    In EAGLE 5 you can use so-called "xref labels" that show at least
    the net name automatically. If you use the FRAME command for
    drawing a frame with columns and rows, you even get the information
    where the net continues on the next/revious sheet.
    See help LABEL and help FRAME for details.
    If you prefer the PORT symbols, simply use the frames.lbr
    of version 4.1 or download dport.lbr from the CadSoft website.
    BTW: This is the german support group.
    Richard Hammerl
