EAGLE Support (Deutsch) drillegend.ulp Symbol Table NOT Selectable
  • Views 930 views
I used "drillegend.ulp" to generate drill symbols and the drill legend
table. They appear on layer 144 as expected. The drill symbols that are
drawn inside the board outline can be grouped and deleted. However, the
drill legend table that is drawn below the circuit board outline can not be
grouped. I can not move or delete any elements in the table. I am running
Eagle 5.6.0 Standard. Might this issue be due to the board size
restrictions in Standard? (drill-legend.ulp works correctly)
Jeff Rockel
WI, USA
Browser-Zugang zu den CadSoft-Support-Foren auf
http://www.eaglecentral.ca
    :blush: Should have known! I've been caught by that before, especially
    when I put a part on the bottom.
    Thanks a million!
    Jeff Rockel
    WI, USA
    Did you activate layer 23 (tOrigins)? This is a little trap image
    r
