EAGLE User Chat (English) How to remove extra lines
  • Subscribers 187 subscribers
  • Views 508 views
The attached lib contains one package. of a capacitor.
How do i remove the extra lines.
Sometimes i can remove extra line poarts, sometime not.
What could be the reason?
Regards
Harry
    Basically, use the ARC command rather than the circle command. Temporarily
    change the layer of the circles to something else (i.e. top). Then click on
    ARC and start the arc at the "(" of your outline. Make the arc as big as
    the circle. Then move the cursor until it meets the other ")" of your
    outline. Do this until you get both of them to your liking. You may have to
    experiment. Then delete the original circles. HTH
    -Dave Pollum
