EAGLE User Chat (English) v7.7 still rocks
  • Replies 8 replies
  • Subscribers 187 subscribers
  • Views 2165 views
v7.7 still rocks
dukepro
dukepro over 6 years ago
All,
It's been 3 years since AD chose a different path for licenses.  I would
like to announce that the Ultimate edition of Eagle v7.7 is still
chugging along nicely on systems that are not connected to the
Internet.  Additionally, I haven't had to spend anything to use it...
not even a nickel!  It's still doing everything I need to do.
When v7.7 is no longer adequate, I will seek solutions that offer
off-line licensing.  If AD/Eagle is among that group, we'll talk again.
If not, well... that's fine, too.
I see that many of the pre-v8 users still check this newsgroup on
occasion.  It's a good thing.  However, I do miss Olin.  It was always
refreshing to read his matter-of-fact posts.
I know that Jorge was in the middle of a firestorm about this time in
2017.  I believe he handled it very well considering how poorly the
transition was was managed at upper levels.  My hat's off to you,
buddy!  You had a tough job and you took point on it.
My best to Jorge and the Eagle crew, and to all the Eagle users both
pre- and post-v8.
Enjoy,
    - Chuck
att1.html.zip
    autodeskguest over 6 years ago in reply to autodeskguest
    Am 21.01.2020 um 20:37 schrieb Morten Leikvoll:
    On 1/21/2020 19:10, Rob Pearce wrote:
    On 21/01/2020 14:21, Chuck Huber wrote:
    I would like to announce that the Ultimate edition of Eagle v7.7 is
    still chugging along nicely on systems that are not connected to the
    Internet.
    Still working fine here, too, but having played with V9.5 there are a
    couple of things I will definitely miss when I'm forced to go back to
    V7 - the "preserve angles" move option and the obstacle avoidance
    routing are both very useful, as is the live DRC.
    Ive tested the 9.x and found a few nice things, but unfortunately they
    are not worth the running cost trap. The live-DRC was too slow on my
    large designs tho, and somthing didnt behave like I was used to, so it
    caused some minor annyoances, but probably sortable.
    What I miss most from the new versions is proper differential
    class/widh/spacing management based on layer stackup, and diff DRC.
    Using the same general clearance parameters as diff spacing like Eagle
    7.7 does, just doesnt work well, and a complex stack makes it an even
    bigger headace.
    Second, miss somewhat placement syncronized layout block features.
    I have some scripts to somewhat help me do both of these today, but I
    think I would pay to get those features if they work well.
    I wanted to test a 9.x version but it did n't even install without internet.
    So nothing ,for me. image
    Joern Paschedag
    shabaz over 6 years ago in reply to Sean_Miller
    Hi Sean,
    Perfect. This will be very useful!
  • Sean_Miller
    Sean_Miller over 6 years ago in reply to shabaz
    If you ever wanted to make a programmer for an ESP8266 at the exact time you wanted to learn KiCAD, I made a tutorial just for you:
    https://www.youtube.com/watch?v=gldUB57FRP4
    It's a few version back, I'm sure, though, but I take it through all the steps.
    See ya',
    -Sean
    Internet.
    couple of things I will definitely miss when I'm forced to go back to V7
    - the "preserve angles" move option and the obstacle avoidance routing
    bigger headace.
    Internet.
    autodeskguest over 6 years ago in reply to dougw
    Am 21.01.2020 um 16:06 schrieb Douglas Wong:
    I'm still using 6.5 without any problems.
    https://www.element14.com/community/message/287414
    You should go to 6.6 that was the latest version.
    Joern Paschedag
    shabaz over 6 years ago in reply to dougw
    Hi Chuck, Doug,
    Same here. I'm on an old version too, although, I've recently downloaded Kicad, to start getting used to it. It might be a while till I'm confident enough to use it!
    It's defaults are (for EAGLE users) strange, but luckily configurable, especially some config param to make the zoom work like EAGLE for comfortableness.
    My first experiment so far.. just some nonsense arrangement of bits!
    dougw over 6 years ago
