EAGLE User Chat (English) Need curved rectangular through-hole pad in Eagle
  • Subscribers 187 subscribers
  • Views 2472 views
bino
bino over 6 years ago
Hello
I need to create a rectangular through-hole pad with a slightly curved corner. For SMD pads there is an option available for curving the corners. But for rectangular through-hole pad their no option for curving the corner.
Please help me out how to curve the corners of rectangular through-hole pads.
Please find the attached img. for a better understanding of the requirement.(In image blue coloured is the drill and green is copper)
Thanks!
    autodeskguest over 6 years ago
    On 6/10/2020 10:23 pm, Bino Mani wrote:
    Hello
    Thanks!
    https://www.element14.com/community/message/296503
    Just so you are aware, Eagle can produce what you are after but not with
    a simple select and click.
    My knowledge of Eagle stops at v7.7 so later versions may provide the
    feature you are after.
    It's simple process but lengthy and needs an understanding of how the
    DRC rules affect/change the size of the pads when that package appears
    on the board.
    You need to create the desired package in the library and yet, there,
    the pads are still not what you want. Within that package you need to
    create custom pads (known in the HELP as 'Arbitrary Pad Shapes')
    Essentially you lay down a pad in the package editor and place a polygon
    over it, of the desired shape. Choosing the wire width of the polygon
    defines the radius of the corners.
    In the package editor you would set the pad size (Don't use Auto). Doing
    that does not guarantee the pad will not grow once on the board editor.
    The change of size is controlled by the DRC rules you have chosen. They
    need to be selected with consideration of the scale of your design.
    I'll leave it there. I suspect you will accept square corners.
    All the best
    Warren
    ... use NNTP://news.cadsoft.de and a functional news reader like
    Thunderbird!
    This email has been checked for viruses by Avast antivirus software.
    https://www.avast.com/antivirus
    Am 06.10.2020 um 11:23 schrieb Bino Mani:
    Hello
    Thanks!
    Actually what you need the curves for?
    Please name the device.
    IMHO there is no possibility in eagle except you make it a device.
    If its to avoid a high voltage corona effect then use round pads.
    Joern Paschedag
    dougw over 6 years ago in reply to autodeskguest
    Understood, but his picture shows a round through hole with a rounded square copper pad.
    autodeskguest over 6 years ago in reply to dougw
    You typically use the mechanical layer to define custom slots.
    https://www.element14.com/community/message/296494
    It probably violates rule checks, but could you just place a rounded SMD pad on top of a smaller square through-hole pad?
  • charlieo21
    charlieo21 over 6 years ago
    Maybe this could help you.
