EAGLE User Chat (English) spacing between dimension and copper pour, how to set ?
  • Views 3519 views
Is there a way to set the clearance between copper pour and the dimension of
my board ? I did look for this setting in the manual/google/etc but no
luck...
Copper pour keeps a distance of 0.04 mill (1 mm) between the dimension
outline of my board and the copper pour (I have defined the copper pour
polygon outline bigger i.e. outside than my dimension rectangle).
What I would like to achieve is that copper pour will just be flush with my
dimension.
Any idea's....?
Carel.
  • frederik1
    frederik1 over 5 years ago in reply to e14 Contributor
    Hi Carel image
    11 years later, I just wanted to let you know that your thread is still useful. I had never even heard about the design rules tab before you mentioned it.
    Thank you so much for sharing your solution, unlike what many others probably would have done. It is genuinely appreciated.
    Hope you're doing good and wish you the absolute best in the future!
    Nevermind, I have found the setting....never expected it to be in a design
    RULE setting dialogue...distance tab:  copper-dimension  image
    Carel.
    "pc5m" <pc5m@xs4all.nl> wrote in message
    news:hva9s2$50j$1@cheetah.cadsoft.de...
    of my board ? I did look for this setting in the manual/google/etc but no
    luck...
    my dimension.
    Any idea's....?
    Carel.
