EAGLE User Chat (English) Ripup top-bottom groundplane by command: all gnd via's gone....
  • Views 1195 views
I stumbled into this behaviour:
- double sided board
- top and bottum has GND copper pour's
- top and bottum pours connected at several places by some via's (named GND)
All fine so far, however when I ripup GND (e.g. to change the copper pour
area's) by command : "ripup GND" all my via's are gone !
When I just select the ripup command (toolbar) by mouse and select the (not
visable) copper pour polygon edge, the gnd pour is removed but the via's are
still there (and that is good.....).
Is the above "normal" behaviour ? or am I doing something stupid...also
selecting by mouse is tedious, is there also a command/setting to ripup gnd
AND preserving the via's ? Tried the "lock" command, but that seems not to
work for via's...
Thanks in advance,
Carel.
    On 6/16/2010 6:44 AM, pc5m wrote:
    GND)
    pour area's) by command : "ripup GND" all my via's are gone !
    (not visable) copper pour polygon edge, the gnd pour is removed but the
    via's are still there (and that is good.....).
    gnd AND preserving the via's ? Tried the "lock" command, but that seems
    not to work for via's...
    Thanks in advance,
    Carel.
    see HELP RIPUP. the ripup command not only removes traces, it also
    changes a polygon from "filled" display to "outline" display.
    Hi Carel,
    It sounds like you are telling it to ripup the entire signal.
    The command ripup @; will ripup all the polygons but nothing else.
    Otherwise, select the border of the polygon and do use the ripup command.
    Doug
    "pc5m" <pc5m@xs4all.nl> wrote in message
    news:hvakgl$n7o$1@cheetah.cadsoft.de...
    GND)
    Thanks in advance,
    Carel.
