EAGLE User Chat (English) Via's and solder mask
  • Replies 7 replies
  • Subscribers 187 subscribers
  • Views 1598 views
As of now all my via's are NOT covered with solder mask.
Hoe can I cover all via's with solder mask?
Harry
    e14 Contributor over 16 years ago in reply to e14 Contributor
    That's it, changed it to 0.02inch
    "James Littlefield" <jal@alum.mit.edu> wrote in message
    news:hvu6p1$vc$1@cheetah.cadsoft.de...
    The procedure described in the faq works for me.   Are you sure that your
    limit is set to a value greater than the drill used for the vias?
    0.5mm is pretty close to 0.019685in so maybe you need to adjust the limit
    up just a tad?
    Jim
    Harry H. Arends wrote:
    >> This also doesn't work as I expected to be.
    >> My via's have a size of 0.019685inch.
    >> My minimum drill size = 0.5 mm
    >> In the Mask tab I enter 0,5 mm in the Limit box and then click on Apply
    >> but nothing changes.
    >> In layer 29 and 30 still the solder stop masks are visible.
    >> "Terri Miller" <tmiller@sunstone.com> wrote in message
    >> news:hvtcg1$r1r$1@cheetah.cadsoft.de...
    >>> "Harry H. Arends" <info@oldtimetech.nl> wrote in message
    >>> news:hvt9rh$fha$1@cheetah.cadsoft.de...
    >>>> Harry
    >>> Hello Harry,
    >>> Here is the information under FAQ on the CadSoft website...
    >>> EAGLE generates by default a solder stop mask for each Via (also for
    >>> Pads and SMDs, of course). This means the Via is free of coating
    >>> material. The solder stop mask is drawn automatically in the layers 29,
    >>> tStop, for the top side and 30, bStop, for the bottom side. The size of
    >>> the solder stop mask can be determined in the Design Rule's Mask
    >>> settings. See the values for Stop. By default the value is fixed to 4
    >>> mils. Minimum and Maximum are set to the same values therefore.
    >>> If you want to have a diameter-dependent mask you could also define a
    >>> certain percentage. The resulting value can be limited by a minimum and
    >>> a maximum.
    >>> In order to have vias coated, EAGLE allows you to set the solder stop
    >>> Limit in the Design Rules' Mask tab. Here you can define a value which
    >>> is dependent on the drill diameter of the via. Let's assume you would
    >>> like to set the Limit to 0.012 inch. Now all vias in the layout up to a
    >>> drill diameter of 0.012 inch will be covered with coating material. All
    >>> those vias that have bigger drills will stay uncovered.
    >>> In case you want to have some smaller drilled vias uncovered, you have
    >>> the possibility to select vias out of those that are covered in order to
    >>> uncover them. This can be done with the command CHANGE STOP ON | OFF in
    >>> the Layout Editor. This also works for groups.
    >>> By the way: It is allowed to draw areas that should remain free of
    >>> coating material in the tStop/bStop layers directly. But it is not
    >>> possible to delete certain automatically generated solder stop symbols
    >>> there. You have to deal with Limit and CHANGE STOP ON | OFF instead.
    >>> Terri
    your limit is set to a value greater than the drill used for the vias?
    limit up just a tad?
    Jim
    >>> Harry
    >> Hello Harry,
    >> 29, tStop, for the top side and 30, bStop, for the bottom side. The
    >> size of the solder stop mask can be determined in the Design Rule's
    >> Mask settings. See the values for Stop. By default the value is fixed
    >> to 4 mils. Minimum and Maximum are set to the same values therefore.
    >> and a maximum.
    >> a drill diameter of 0.012 inch will be covered with coating material.
    >> All those vias that have bigger drills will stay uncovered.
    >> to uncover them. This can be done with the command CHANGE STOP ON |
    >> OFF in the Layout Editor. This also works for groups.
    >> Terri
    In the Mask tab I enter 0,5 mm in the Limit box and then click on Apply but
    nothing changes.
    >> Harry
    Hello Harry,
    EAGLE generates by default a solder stop mask for each Via (also for Pads
    and SMDs, of course). This means the Via is free of coating material. The
    solder stop mask is drawn automatically in the layers 29, tStop, for the
    top side and 30, bStop, for the bottom side. The size of the solder stop
    mask can be determined in the Design Rule's Mask settings. See the values
    for Stop. By default the value is fixed to 4 mils. Minimum and Maximum are
    certain percentage. The resulting value can be limited by a minimum and a
    maximum.
    Limit in the Design Rules' Mask tab. Here you can define a value which is
    dependent on the drill diameter of the via. Let's assume you would like to
    set the Limit to 0.012 inch. Now all vias in the layout up to a drill
    diameter of 0.012 inch will be covered with coating material. All those
    In case you want to have some smaller drilled vias uncovered, you have the
    By the way: It is allowed to draw areas that should remain free of coating
    material in the tStop/bStop layers directly. But it is not possible to
    delete certain automatically generated solder stop symbols there. You have
    Terri
    You are right.
    I forgot about that not working if the drill is >0.
    news:hvtg2r$alq$1@cheetah.cadsoft.de...
    That doesn't work.
    But also selecting stop in the via properties doesn't shows any change on
    layer 29-30
    "Doug" <doug@midnitesolar.com> wrote in message
    news:hvtca1$qmr$1@cheetah.cadsoft.de...
    >> With only the via layer on, select them as a group and then
    >> Change-Stop-on.
    >>> Harry
    That doesn't work.
    layer 29-30
    Change-Stop-on.
    >> Harry
    Harry
    Hello Harry,
    solder stop mask is drawn automatically in the layers 29, tStop, for the top
    side and 30, bStop, for the bottom side. The size of the solder stop mask
    can be determined in the Design Rule's Mask settings. See the values for
    Stop. By default the value is fixed to 4 mils. Minimum and Maximum are set
    maximum.
    In order to have vias coated, EAGLE allows you to set the solder stop Limit
    diameter of 0.012 inch will be covered with coating material. All those vias
    possibility to select vias out of those that are covered in order to uncover
    them. This can be done with the command CHANGE STOP ON | OFF in the Layout
    Terri
    With only the via layer on, select them as a group and then Change-Stop-on.
    Harry
