EAGLE User Chat (English) "Speed" and "Search" of the forum options
  • Views 617 views
Recent posts regarding the Element14 arrival prompted many to "help" with
"testing" so I'm not going to prolong your agony with further similar
discussion. Given time the forum sites will improve or die.
What I wanted to add are two points.
1)The first affects me and others living on my side of the globe (New
Zealand).
The Element14 site will not be a place I will visit simply because it takes
too long to get the data to me. An IP search stated it serves from
Switzerland. Here, data from the UK is known to be slow. Just to many nodes
to reach us. Now this example from Switzerland is on that list, assuming the
bottleneck is not with the hosting server. Surprisingly I have never
considered Germany a slow source.. On the other hand the Eagle Central site
serving out of Arizona USA is fine being 1/4 of a world closer.
I would be interested in a response from any Australian or SE Asia based
members on their experience.
2) Searching for previous posts is a challenge. I'm new to news readers
having been a forum person over the years. I do find the newsreader faster
(better) on a daily basis for checking the newest postings. I have yet to
understand how to obtain the historical posts from the newsreader feed. Some
tips would be appreciated.
Eagle Central serves my needs most of the time. It's the quickest reference
I have found, so far, for the Eagle bug fixes over all the version 5
releases. Found in  the "Announce" forum duplication on Eagle Central
... but I have one gripe, the search engine, and forums with the best search
ability win the forum wars.
I wanted information on PAD_NAMES as in "set PAD_NAMES ON | OFF"
The search engine saw the Underscore as whitespace and so the search became
"PAD" and  "NAMES". That gave far to many postings to check. So the next try
was to quote my phrase "PAD_NAMES".
The response was  the same as before. Some time searching the FUDForum did
not find anything that helped. A 2005 post from the developer says AND of
keywords is good enough. !!!
Element14 was more successful. The underscore was converted to whitespace
and it did find "pad names"
So there's the dilemma. I appears there is no support avenue in place that
enables me to access previous postings without some compromise or work
around.
If you can assist please let  me know.
Warren
    not if you have them in your local message base.
    It depends on your news client. I can set the limits (how many
    messages pulled) in a general setting, and override it for each group
    in the group properties. Set it to 50000 and you likely get enough
    information (Cadsoft keeps the messages very long).
    Get a decent news client, it should have the best search capabilities.
    If needed, use grep or similar to search the message base directly.
    My old Forte Agent searches exactly for the string "PAD_NAMES".
    Oliver
    warrenbrayshaw wrote on Sat, 03 July 2010 04:51
    takes
    nodes
    assuming the
    site
    I don't think this has much to do with geographic location but rather how
    well connected the servers are, which effects the number of routers between
    you and the server.
    e14 Contributor over 16 years ago in reply to e14 Contributor
    Robert Pearce schrieb:
    On Sat, 3 Jul 2010, Warren Brayshaw wrote to us saying :
    It isn't generally possible to obtain historic posts. The NNTP system
    was designed in the days of 1200 Baud modems and 40MB drives. It tries
    quite hard to minimize the amount of redundant data being stored, and
    expects NNTP servers to purge old posts on a fairly regular basis. It's
    unusual to find servers that carry anything over a month old.
    That's only half of the truth.
    It's correct that most (if not all) news servers have expiration times
    for the posts, but these times vary significantly.
    In Usenet, 30 to 90 days are common. However, the CadSoft servers (at
    least the support and userchat groups) have much longer times.
    Currently, I can access posts back to October 2005 image in support.eng
    (as an example).
    The assumption was always that news reader clients would allow the user
    to save any post that was of longer term interest. My client (Turnpike)
    has a very clear "Keep" button on the message viewer which instructs it
    not to expire its local copy of the post being viewed. But that still
    relies on me fetching (and reading) these groups faster than the CadSoft
    server's expire time.
    Most newsreaders can be configured for "online" or "offline" use of a
    group. In online configuration, all posts are loaded exactly when you
    read them, with nothing but a local cache eventually. Using groups
    offline means all content is stored locally. This causes longer download
    times when connecting to the server, since all measages have to be
    downloaded - but then it allows for searching in the message bodies, not
    only the headers.
    Your (Warren) problem might be a default configuration of OE that
    downloads only the headers or posts of the last 30 days. To get all
    available posts, you need to unsubscribe, change the setting, and then
    subscribe to the groups again (AFAIK - I am not using OE).
    And while you're at this, you might consider using a newsreader that
    cares more about international standards, OE ist somewhat ignorant in
    this concern. There are many free programs (Thunderbird, SeaMonkey,
    Forte Agent etc.) - and at least the first two ask you how many headers
    resp. posts they should download when you subscribe to a group.
    There is a web site somewhere that has been plugged in to every public
    NNTP feed in the world, and has been archiving it all for posterity. So
    Google is often quite good at digging up old UseNet postings.
    This only helps if Google archives a particular group - which is not the
    case for the support groups at the CadSoft news server. I am not aware
    of an archive that keeps older posts of the CadSoft newsgroups (which
    are not part of the Usenet, BTW).
    For web access and searches (if the newsreader is configured for online
    use), the mirror at eaglecentral is fine - provided the search function
    works as expected...
    Tilmann
    Rob Pearce                       http://www.bdt-home.demon.co.uk
    The contents of this | Windows NT crashed.
    message are purely   | I am the Blue Screen of Death.
    my opinion. Don't    | No one hears your screams.
    believe a word.      |
