EAGLE User Chat (English) wiring diagram
  • Replies 12 replies
  • Subscribers 189 subscribers
  • Views 2217 views
wiring diagram
Hello all,
Has anyone been able to get Eagle to work for wiring diagrams.  When I
try and create some schematic only components (wire housings, ferrules,
etc..) I get error messages that there is no PCB footprint.  OF COARSE,
this is for the wiring I plan to associated with the board I have created.
We are getting to crunch time and I need to get this moving.  Maybe I
just need to have the SolidWorks team work on this for me.
Ryan
    On 8/31/2010 1:20 PM, Ryan B wrote:
    Hello all,
    Ryan
    You can draw directly into the schematic, or make library symbols that
    don't have an associated package and use them as device. The problem
    with either of these approaches as that you can't then rubberband the
    nets with the parts because you can not include pins in the device
    without the package footprint. This makes any changes somewhat tedious.
    As Olin suggested, look at the drawing frames for an example of devices
    without footprints. There are also some libraries on the CADsoft website
    with common schematic symbols for AC power and such.
    I would prefer if EAGLE would allow schematic pins without an associated
    package for just the problem you have run into.
    Ryan B wrote on Tue, 31 August 2010 16:20
    Of course.  Schematic capture is one of its main functions.
    Quote:
    When I try and create some schematic only components (wire housings,
    ferrules, etc..) I get error messages that there is no PCB footprint.
    If you want to put things only on the schematic that aren't real parts on
    the board, you can either draw them directly in the schematic or use a
    canned symbol from a library.  Annotation text is a good example of the
    former, and schematic frames for individual pages are common examples of
    the latter.
    As always, reading the manual saves time.  It sounds like you've already
    wasted more time bumping around in the dark than it would have taken to
    read the manual and do it correctly from the start.
