EAGLE User Chat (English) wiring diagram
  • Replies 12 replies
  • Subscribers 189 subscribers
  • Views 2218 views
wiring diagram
Hello all,
Has anyone been able to get Eagle to work for wiring diagrams.  When I
try and create some schematic only components (wire housings, ferrules,
etc..) I get error messages that there is no PCB footprint.  OF COARSE,
this is for the wiring I plan to associated with the board I have created.
We are getting to crunch time and I need to get this moving.  Maybe I
just need to have the SolidWorks team work on this for me.
Ryan
    On 9/7/2010 5:10 AM, Ryan B wrote:
    On 9/3/2010 9:19 AM, Ryan B wrote:
    >> On 8/31/2010 4:20 PM, Ryan B wrote:
    >>> Hello all,
    >>> created.
    >>> Thanks
    >>> Ryan
    >> Hell all,
    >> I seem to have a way around this, I am making all the pins on the supply
    >> direction. While this allows for a symbol without a package to be used
    >> it does connect all nets together; although since the drawing will not
    >> be a PCB this is not an issue. These cable drawings will be for ref.
    >> only and then used to translate into manufacturing drawings in a cad
    >> system.
    >> For those of us here that will be trouble shooting and repair the cable
    >> diagrams made in Eagle will serve as a pin-pin reference.
    >> Thanks
    Hello all,
    After some playing around last week I have decided to go ahead and
    create generic packages for the cable connectors (just a group of pads
    close to the layout of the terminations inside the connectors). This way
    I am able to define separate nets on the schematic and label them. I am
    using the net name and labeling to denote the conductor color of each
    connection.
    Thank you for all the input.
    yup, i've got quite a few "dummy" packages, but they are annoying when
    they show up in your board view.
    >> Hello all,
    >> created.
    >> Thanks
    >> Ryan
    Hell all,
    system.
    Hello all,
    way I am able to define separate nets on the schematic and label them.
    I am using the net name and labeling to denote the conductor color of
    each connection.
    e14 Contributor over 16 years ago in reply to e14 Contributor
    On 9/1/2010 10:43 PM, Lorenz wrote:
    >>>> created.
    would it be possible to add a new pin direction 'no_pad' or something
    to the effect that symbol-only devices are possible?
    just reiterating my support for symbol only devices.
    But I think it better to have it at the package level than at the pin
    level... there may be advantages to having it at the pin level, such as
    a pot mounted on a board, the 3 terminals are part of the package and
    the case can be shown grounded on the schematic without incurring a
    footprint pad. This could also be done in the current system with a
    special footprint, since there will need to be a ground connection
    somewhere. Maybe someone can think of a better reason to make it a pin
    direction rather than a package level option 'off_board' ??
    Hello all,
    Ryan
    Hell all,
    system.
    e14 Contributor over 16 years ago in reply to kcadsoft
    >>> created.
    Lorenz
    Gary Gofstein wrote on Tue, 31 August 2010 18:32
    It will not work if the device is created with pin directions
    "passive", although "supply" will allow
    the device to not need an associated package!
    I didn't realize this was limited to the supply pin direction.  That means
    this method comes with certain ERC issues.
  • kcadsoft
    kcadsoft over 16 years ago in reply to e14 Contributor
    >> created.
    I sometimes use SET CHECK_CONNECTS OFF; might be suitable.  From the
    menu select Options | Misc (tab) | Check Connects
    From the help:
    "The ADD command checks whether a pin has been connected to every pad
    (with CONNECT). This check can be switched off. Nevertheless, no board
    can be generated from a schematic if a device is found which does not
    have a package."
    Actually this should read
      "The ADD command checks whether every pin has been connected to a pad..."
    I've changed that in the online help for the next version.
    Klaus Schmidinger
    Pleidolfweg 15                          Email:   kls@cadsoft.de
    On 8/31/2010 2:21 PM, Olin Lathrop wrote:
    Gary Gofstein wrote on Tue, 31 August 2010 16:59
    >> I would prefer if EAGLE would allow schematic pins without an
    >> associated package for just the problem you have run into.
    It can. Ground symbols are a common example of this. A device can have a
    symbol without a package.
    Thank you Olin, that's very good to know. It will not work if the device
    is created with pin directions "passive", although "supply" will allow
    From the help:
    have a package."
    Neil
    associated
