EAGLE User Chat (English) Can't enter values in schematic
  • Replies 9 replies
  • Views 2331 views
I have created several parts but I can't enter the values on the schematic.
I have >VALUE on the Value layer but on the schematic it displays the device
name.
If  I go to the info page, the device setting is Greyed out.
What am I doing wrong?
Thanks Wallace
    e14 Contributor over 16 years ago in reply to e14 Contributor
    Marsheng schrieb:
    Something funny here.
    If I search documents and settings for eaglerc.usr - No files found.
    If I search Cadsoft, it finds the file.
    I had subdirectories and system selected. Looks like I needed to add Hidden
    as Cadsoft must be hidden directory.
    No - the whole "application data" tree is hidden.
    However, besides spending so much time looking for eaglerc.usr you'd
    eventually better correct the libraries in question and set VALUE to ON
    in the particular device(s)...
    Tilmann
    P.S. Please do not top-post (placing your answer /above/ the quote) -
    this makes a thread hard to follow. Thanks.
    Cheers Wallace
    "A. Zaffran" <alf@cadsoft.de> wrote in message
    news:i7hkg7$uve$1@cheetah.cadsoft.de...
    Am 24.09.2010 01:13, schrieb Marsheng:
    >> Hi Alfred
    >> XP
    >> Thanks Wallace
    Please search the eaglerc.usr with explorer.exe, in
    C:\Documents and Settings\wallace\Application Data\Cadsoft\Eagle
    Alfred Zaffran
    ___________________________________________________
                                Web:   <www.cadsoft.de>
    Geschäftsführer: Dipl.-Ing. Klaus Schmidinger,
    Dipl.-Ing. (FH) Rudolf Hofer, Bodo Badnowitz
    Hi Alfred
    XP
    Thanks Wallace
    Alfred Zaffran
    Hi Alfred
    XP
    Thanks Wallace
    news:i7fec2$b1i$3@cheetah.cadsoft.de...
    Am 23.09.2010 13:28, schrieb Marsheng:
    >> A few things
    >> It would help if the manual was accessed from the package. I have only
    >> just
    >> found it in the directory !!!
    >> I  have checked my settings and the>VALUE and  the layers seem to be
    >> correct and the same as other symbols in the library.
    >> I cannot find eaglerc.usr. I've search my whole machine.
    Which System you are use?
    Windows 2000/XP/VISTA/WIN7? Linux? Mac?
    Alfred Zaffran
    A few things
    It would help if the manual was accessed from the package. I have only just
    Alfred Zaffran
    A few things
    I  have checked my settings and the >VALUE and  the layers seem to be
    Do I have to change the switch manually in the USR file when and if  I find
    it ?
    Thanks Wallace
    "Warren Brayshaw" <warrenbrayshaw@paradise.net.nz> wrote in message
    news:i7erd5$baf$1@cheetah.cadsoft.de...
    "Marsheng" wrote
    >> I can't seem to find the page with the switch.
    >> I don't have a eaglerc.usr file either ?
    >> Suggestions please.
    Ensure you understand the section in the manual entitled "Definition of a
    Simple Resistor" (Chapter 8.1, possibly)
    It speaks of your situation where the Device Name is displayed in the
    Value
    field.
    Again in the manual, it describes how to locate the eaglerc.usr file. It's
    location will depend on how you have set up  your computing environment
    The switches in the eaglerc.usr file are described in the manual section
    "Options for Experts in eaglerc"(Chapter 10.6,  possibly)
    Warren
    Suggestions please.
    It speaks of your situation where the Device Name is displayed in the Value
    field.
    Warren
    Suggestions please.
    Thanks Wallace.
    name.
    The devices have set "VALUE OFF" in their definition (in the library),
    that means you can't change their value.
    There is a switch in eaglerc.usr that allows overriding this setting.
    Tilmann
