EAGLE User Chat (English) Signal Integrity Check
  • Views 784 views
Hello all,
I was wondering if there was a way to run some tests on the PCB layouts
in Eagle?  signal integrity, thermal management and the like.  I have
two boards that I believe are close to being ready for fab, but I would
like to be able to ensure my designs prior to fabrication so that I can
be more likely to get stable systems on fab and population.
Thank you
Ryan
    On 9/23/2010 6:37 AM, Ryan B wrote:
    Hello all,
    in Eagle? signal integrity, thermal management and the like. I have two
    boards that I believe are close to being ready for fab, but I would like
    to be able to ensure my designs prior to fabrication so that I can be
    Thank you
    Ryan
    Well, the best check is to build them and measure their performance if
    they are analog. If they are digital, well, same thing!
    There are some ULP's that help estimate temperature rise, delay time,
    etc in traces but these things should be designed into your board from
    the start if they are important.
    A real package that can take a board definition and run the checks you
    are talking about is usually only done by giant corporations with $$$$.
    Even then, simulation is only simulation, reality is reality.
    Make some prototype boards to get any problems ironed out, then pray and
    go to production...
