Hello...
How to find net in schematic?
When executing ERC I got
ERROR: 2 OUTPUT Pins on net N$4
But where is that wire? How to find it.
Hello...
Na 5.10.2010 17:12, Stefan je pisal:
Am 04.10.2010 21:24, schrieb Warren Brayshaw:
>> Use the SHOW command via the command bar.
>> show N$4
>> The net will be highlighted
>> Warren
You can also use
run find N$4
this cmd will center and zoom the net
That's even beter... Thanks again!
Slavko.
show N$4
Warren
You can also use
run find N$4
Na 4.10.2010 21:24, Warren Brayshaw je pisal:
show N$4
Warren
Thanks.. That works.
4.16
Ah ok, that would explain this...
show N$4
Warren
Na 4.10.2010 19:49, Markus Rudolf je pisal:
>> Does not...
Which Eagle version?
Markus
4.16
Does not...
Markus
Na 4.10.2010 19:06, Markus Rudolf je pisal:
I think you can double click the error and it will jump right to it?
Markus
Does not...
Markus
