EAGLE User Chat (English) SCR file export...
  • Views 641 views
SCR file export...
Hello...
I want to export netlist and partlist from schematic.
I wan't to write export.scr but got problem as I can't figure how to set
filemane.
ie if export.scr is
export netlist;
export partlist;
then program ask's for filename (I don't want that)
the
export netlist filenameNnet;
export partlist filenamePart;
work's but the output is into 'curent folder' not the folder with
oppened file.
So how to set filename to export to the same folder as schematic is with
same name as schematic and just extension changed.
Thanks.
I know that is newbie question but I didn't make any script or ulp all
years I using eagle. (right now I need extra func image)
    Na 5.10.2010 22:56, Warren Brayshaw je pisal:
    "eslavko"<eslavko@gmai.com>  wrote in message
    news:i8el51$mfl$1@cheetah.cadsoft.de...
    >> Hello...
    >> filemane.
    >> ie if export.scr is
    >> export netlist;
    >> export partlist;
    >> the
    >> oppened file.
    >> Thanks.
    The following is what I think you are saying.
    You have an project open and then without closing that project you open a
    schematic or board from another folder.
    When you export the file it ends up in the 'open project' folder and not in
    the folder of the sch/brd that was open when you ran the script.
    If that is the case  I would write a small ulp that fetched the full path
    name to the open brd/sch folder and runs the export using that. The ulp
    would be given one argument which is the type of export you wish and it
    would return to the script performing the desired export to the folder of
    the currently open editor.
    your script
    your script
    run MyExportULP  NETLIST
    your script
    run MyExportULP  PARTLIST
    your script
    That's the technique. Maybe someone has written such a ULP already and  will
    post it.
    Warren
    That's nice.
    The ulp can export both (netlist and partlist) at once (just one call)
    and no script used at all, just ulp.
    "eslavko" <eslavko@gmai.com> wrote in message
    Hello...
    filemane.
    ie if export.scr is
    export netlist;
    export partlist;
    the
    oppened file.
    Thanks.
    your script
    your script
    your script
    your script
    post it.
    Warren
    Na 5.10.2010 9:46, eslavko je pisal:
    Hello...
    filemane.
    ie if export.scr is
    export netlist;
    export partlist;
    the
    oppened file.
    Thanks.
    Can't be done?!?
