EAGLE User Chat (English) Wiring diagram.
  • Subscribers 187 subscribers
  • Views 423 views
Wiring diagram.
Hello...
I'm just wonder if I can import another one eagle.brd file onto already
oppened one?
Ie I want to open two (or more) eagle brd files at once as I wan't to
draw 'block' diagram how board's are interconnected (ie wiring diagram)
Is that plausible? (eagle 4.16)
  • Richard_H
    Richard_H over 15 years ago
    Am 18.10.2010 12:11, schrieb eslavko:
    Hello...
    oppened one?
    to combine two or more layouts into one common brd file:
    • Open the board where the objects are you want to use in
      your new project
    • Use DISPLAY to show all the layers
    • Select the objects with GROUP
    • Activate the CUT command and click into the drawing in order
      to copy it into the clipboard
    • Now open the new board
    • Use the PASTE command and place the previously selected
      group.
    • save board
    • open the next board file
    • Now open the new board and paste the group
    Richard Hammerl
