EAGLE User Chat (English) Board Outline
  • Views 904 views
Board Outline
Making a board with a precise outline...
What is the normal way to specify the board outline in the Gerber files?
Should there be a separate "outline file" or is it just whatever the
outermost contour in the silkscreen is understood to be the routing
contour? Do I need to take the tool size (kerf) into account or just
draw a thin line and let the board house take care of it?
    "Morten Leikvoll" <mleikvol@yahoo.nospam> wrote in message
    news:id52rh$cnu$1@cheetah.cadsoft.de...
    "Richard Hammerl" <ric@cadsoft.de> wrote in message
    news:id350o$1d2$1@cheetah.cadsoft.de...
    >> Width 0 is not supported by Gerber. IMHO your board manufacturer
    >> knows what to do in such a case. He simply will change the width
    >> to a reasonable one and have the board manufactured.
    I do not see any reservation on aperture macro "circle" diameters in the
    Gerber RS-274X Format's User Guide (Part Number 414 100 014 Rev D March,
    2001 from Barco), but maybe the original spec says something about it?
    Then again, I think it is good to use width=0, so that an unexperienced
    manufacturer is forced to stop and think when he finds this aperture.
    Maybe he is forced to stop and think when the width is very small too, but
    you never know.
    Richard is correct here... a zero width is basically an undefined aperture,
    so usually the manufacturer will define the aperture during the tooling
    process.  And no matter what the outline width is, the center of the outline
    is usually considered the actual route path.
    Terri
    e14 Contributor over 15 years ago in reply to Richard_H
    you never know.
  • Richard_H
    Richard_H over 15 years ago in reply to e14 Contributor
    Am 30.11.2010 10:10, schrieb Morten Leikvoll:
    "Tilmann Reh" <usenet2007nospam@autometer.de> wrote in message
    news:id294r$uji$1@cheetah.cadsoft.de...
    >> Don't use width 0, since this generates invalid gerber code (aperture
    >> width 0 is illegal). Don't use thick wires since this might lead to
    >> confusion whether the inner, the center, or the outer sizes are meant.
    >> Don't use the dimension layer since this contains implicit objects (hole
    >> outlines).
    Hm.. I have used width 0, and the gerber is generated. Maybe some
    manufacturer's tools will complain, but it looks like width 0 is supported.
    Richard Hammerl
    outlines).
    I always draw a thin (0.01 mm) contour in the "milling" layer and
    provide that as separate gerber file to the board house. There never
    were any problems (with none of several board houses). AFAIK, providing
    the outline as separate gerber file is pretty common standard.
    outlines).
    In question, talk to them.
    Tilmann
