EAGLE User Chat (English) Duplicate a package or symbol
  • Views 495 views
Hello all,
Often I need to duplicate a package to create variants. I do it by hand,
open the package, display all layers, group, cut, create new package, paste,
then copy/paste the description. This process is slow and prone to errors.
Is there a way to duplicate an object (package or symbol) easily ? As far as
I have seen, the export function of the File menu exports the whole library
and only to a text file.
One way I imagined was to list all the elements of the source package and
rebuild the new package via a ULP. Any better idea ?
Best regards,
Jerome
    "Gary Gofstein"  a écrit dans le message de groupe de discussion :
    ig7vmf$dck$1@cheetah.cadsoft.de...
    >By opening the library in the control panel, it is possible to copy
    >packages and maybe symbols to another library if that's what your looking
    >for.
    >First find the destination library in the cp and right click to select
    >"open".
    >Then locate the package in the other library in the cp and right click and
    >select "copy to library".
    Finally I wrote a couple of ULP to do the job. Fast and efficient image
    Jerome
    On 1/6/2011 1:28 AM, Jerome wrote:
    Hello all,
    paste, then copy/paste the description. This process is slow and prone
    to errors.
    far as I have seen, the export function of the File menu exports the
    whole library and only to a text file.
    and rebuild the new package via a ULP. Any better idea ?
    Best regards,
    Jerome
    looking for.
    "open".
    and select "copy to library".
