EAGLE User Chat (English) Package editor
  • Views 1057 views
Package editor
I've started working with Eagle for about 3 weeks now and love the
accessibility of this software!
Can somebody tell me if there is a possibility to make a cutout (circle) in
a polygon in the package editor?
I've tried it by creating a circle on layer 42 (bRestrict) without any
result.
    e14 Contributor over 10 years ago in reply to e14 Contributor
    Dear Warren,
    Sorry for the late reply, I didn't saw your answer upon today.
    Thanks for the detailed explanation and the effort you have put into!!
    Marcel
    e14 Contributor over 10 years ago in reply to autodeskguest
    Dear Warren,
    Thank you very much!
    Marcel
    autodeskguest over 10 years ago in reply to e14 Contributor
    On 23/01/2016 9:46 a.m., Marcel Charpentier wrote:
    Dear Warren,
    Thank you for your answer!unfortunately I didn't receive the
    library/package as an attachment.Can you please send me this again?
    Thank you in advance.
    Best Regards,
    Marcel Charpentier
    http://www.element14.com/community/message/172225
    Hi Marcel
      you can get it here at EagleCentral, a much better web interface to
    the Cadsoft Newsgroups
    http://www.eaglecentral.ca/index.php/t/52181/b13d95d7be9b217956a2a578d14c80e8/
    Warren
    Dear Warren,
    Best Regards,
    Marcel Charpentier
    Hi Marcel
    Warren
    Dear Warren,
    Thank you for your answer!unfortunately I didn't receive the library/package as an attachment.Can you please send me this again?
    Best Regards,
    Marcel Charpentier
    result.
    Hi
    You need to make the hole part of the polygon edge.
    Attached is a library/package that shows the steps.
    Before you start set the 'Alternate Grid' to finest.
    I've drawn on layer 34 for clarity
    Set the wire width to something greater than your DRC will require. 8mil
    is used here
    Some comments relating to the numbering of the steps.
    (1)
    (a) Draw a circle at the desired point for guidance, It will be removed
    later. Here it has width(8 mil) but you can use a zero width circle
    (filled) and work to it's edge if the circle diameter is critical.
    (b) Draw a polygon edge for each portion of the sections that approach
    the circle, like the tent shape in step 1.
    (c)Don't let two straight sections become aligned or the edges may/will
    become one and  you will have to split them again.
    (3)
    To bend that straight line to an arc, select MOVE, Hold down CTL and
    click in the middle of the straight line and drag to match the shape of
    the guiding circle. It will jump using the standard grid so hold down
    the ALT key to activate the alternate grid.
    (7)
    As you tidy up the the final edges, don't let them cross or be exactly
    upon one another. the polygon will be invalid. Keep the centres of the
    wires slightly apart and yet the wires are still overlapping
    HTH
    Warren
