EAGLE User Chat (English) Hole in bStop?
  • Subscribers 189 subscribers
  • Views 564 views
Hole in bStop?
e5frog
e5frog over 15 years ago
Using Eagle 5.10.
I was going to make something very easy just a 10x10cm board, no traces or
anything, soldermask on top and a hole in the soldermask so that I clear
area for contact.
Didn't bother making a schematic for something so simple but was not able
to get a plain round hole in the mask. image
A colleague of mine have a program dealing directly with the gerber files
so if I made a new layer with the intended hole he could quite easily
combine those two layers and invert the hole-layer so it would make a hole
in the square... looks quite easy when you see it.
Is there any such functionality in Eagle? I'd like to just be able to make
a circle in the bStop layer and then invert that to make a hole instead...
I tried adding a pad but then the top layer would crawl away from that pad
- I guess I could maybe find the settings for the distance between pad and
surrounding layer but that doesn't seem like the easiest way to do it.
One other odd thing that's not related to the topic is that although I
chose an exact size of the board according to Eagle, (it was corner to
corner exactly the desired size) the size had changed after going through
the gerber274x cam. Very odd, in Eagle it looks perfect but at the
manufacturer the size suddenly changes. Any way to avoid that, any way to
improve on that. I had set measurements to mm.
  • e5frog
    e5frog over 15 years ago in reply to e14 Contributor
    Ok, I got it now - it's so easy when you're doing normal designs. The bStop
    layer marks all the holes in the green lacquer.  Duh.
    Thanks, I'm going to go and see where I left my head...
  • e5frog
    I thought the bStop was for the soldermask...
    What layer is usually used for the soldermask, can bStop be used to define
    a hole in that layer?
    Stop, Cream, Finish, Glue? Among those I thought the Stop alternative was
    the most logical.
    I downloaded 5.11 on this computer just to experiment some but I didn't
    manage to put a layer, a layer on top and then a hole in the layer on
    top...
    e14 Contributor over 15 years ago in reply to e5frog
    Fredric <e5frog@gmail.com> wrote:
    Yes I had managed to do that but It basically disappears into the
    background, how do I make that area inversed, the enclosed area is supposed
    to be empty and the area outside of it is supposed to be filled.
    I can't remember if I tried both the rectangle option and the polygon, the
    polygon option is usually very data intense so that's something I'd rather
    avoid.
    The stop layers are negative. Whatever you draw there is exposing copper.
    If you want to see it more clearly, set the stop layers fill pattern and
    color.
  • e5frog
    avoid.
    "Fredric" <e5frog@gmail.com> wrote in message
    news:ihk2sc$tvk$1@cheetah.cadsoft.de...
    Using Eagle 5.10.
    area for contact.
    You can draw in t/bStop directly using a circle with width 0. This makes it
    a filled circle.
