EAGLE User Chat (English) Follow-me router settings
  • Replies 7 replies
  • Views 900 views
I've been using eagle for a few small hobby boards, but the complexity
and density is increasing. For this I'd like to keep doing mostly manual
routing, but without creating DRCs. The follow-me router seems to be a
good choice for what I'd like to do, but I have not been able to figure
out good settings that will allow me to lay out the traces the way I
want them but only use the follow-me functionality in order to be able
to "hug" other traces or route as close as possible to a pad for
example. Does anyone have any settings for the follow-me parameter
dialog that will allow the follow-me router to be more cooperative?
Also, how do I add a via while using the follow-me router?
In both cases I'm trying to use the follow-me router in partial mode.
Daniel
    Daniel Nilsson wrote on Thu, 10 March 2011 15:17
    the phrase "without creating DRCs" refers to not creating DRC
    violations.
    That could definitely have been expressed better.
    Quote:
    Maybe you shouldn't be so sure that the person in the other end that
    you have never met is an idiot and the question is dumb before you are
    sure you understand exactly what the person is asking for.
    Maybe you shouldn't get so upset when someone interprets a poorly worded
    question in a way that wasn't intended.
    Quote:
    If you think the person is asking something stupid then you don't need
    to answer the question.
    Pointing out something is stupid can be useful.
    Quote:
    Yes, I did. But there are a total of 15 cost settings under the
    follow-me tab, plus 3 maximums. In addition to this I think the grid
    plays an important role. What I'm asking for are some "best practice"
    from the people using the follow-me router on how to setup these
    parameters.
    I don't use the follow me router much.  It sounded like a good idea at
    first, but I haven't found it all that useful.  When you're manually
    routing, it's usually because you want traces to have a specific layout,
    like to contain high currents of a switching power supply, make a short and
    direct connection between a microcontroller and its crystal, etc.  In those
    cases, the follow me router does too much stuff on its own I don't want.
    For other traces that just need to get from one place to another but aren't
    critical, I don't need to be envolved at all and can use full auto
    routing.
    You do need to tweak the auto router settings according to what you are
    trying to accomplish.  When I first started using the auto router, I found
    the default settings pretty useless.  You have to go thru the manual and
    understand what each setting does, and play around with it to get some
    intuition on what effects it causes.
    Quote:
    Just playing with the hugging parameter is not giving me the
    result I want.
    OK, so play around with some other parameters.  Again, you really need to
    understand and get some intuition about all the parameters.  It takes more
    work to learn to use the auto router well than for manual routing, but in
    the end it's a nice tool that can take care of a lot of drudge work for you
    if you use it right.
    Quote:
    However, the follow-me router still decides to add vias when a trace is
    going diagonally. This is decision I'd like to
    make on my own, so I assume I need to reduce the cost in the settings
    for some of the step parameters or simply make adding a via very costly?
    Don't assume, know.  Read the manual.  There are settings for the cost of
    diagonal steps, vias, and lots of other stuff.
    On 3/10/2011 3:17 PM, Daniel Nilsson wrote:
    On 03/09/2011 01:39 PM, Olin Lathrop wrote:
    >> Daniel Nilsson wrote on Tue, 08 March 2011 14:52
    >>> Since this was my first post to the forum I'm surprised by this
    >>> unfriendly tone.
    >> You were asking how to do something irresponsible. Not wanting to
    >> "create"
    >> DRC settings is like not wanting a compiler to ever do type checking. I
    >> have little interest in helping people do dumb things like that.
    As I said earlier, you are not getting the question. I have never stated
    that I don't want to create DRCs settings, the phrase "without creating
    DRCs" refers to not creating DRC violations. Maybe you shouldn't be so
    sure that the person in the other end that you have never met is an
    idiot and the question is dumb before you are sure you understand
    exactly what the person is asking for. If you think the person is asking
    something stupid then you don't need to answer the question.
    >> Quote:
    >>> I want to use the follow-me router when doing manual routing in such a
    >>> way that the artwork is not violating any rules (i.e. not causing any
    >>> DRC
    >>> errors).
    >> Then in addition to the proper DRC settings, you also need to set up the
    >> autorouter. Some settings in there are global, but there is also a tab
    >> specific to the follow-me router. Did you look at the hugging parameter I
    >> already mentioned?
    parameters. Just playing with the hugging parameter is not giving me the
    result I want.
    I tried the follow-me mode on one of the tutorials, singlesided.brd and
    there it works a lot better using the default settings of that design.
    One big difference though is that on the tutorial board every pin of
    every component is on the routing grid. That is certainly not the case
    on my designs, I don't think many other real world designs would be able
    to achieve this either. However, the follow-me router still decides to
    add vias when a trace is going diagonally. This is decision I'd like to
    The original question was also on how to add a via manually when using
    /Daniel
    Hi Daniel,
    I hope you are doing well. The "Best Practices" when it comes to EAGLE's
    autorouter is to use the default cost factors, that's the truth. Have
    you tried looking through section 7.6 of the EAGLE manual? It details
    every cost layer and how they affect the routing process, it also gives
    recommended values. The EAGLE manual is included with the EAGLE
    installation in PDF format. If you're a windows user the easiest way to
    get to it is from the Windows desktop. Start-> All Programs-> EAGLE
    Layout Editor-> Manual.pdf. If you're not a Windows user then you'll
    find the manual in the doc folder for the EAGLE installation folder.
    You'll find the routing grid setting in the General tab of the
    Autorouter settings, by default it's set to 50 mils but a more practical
    value would be in the 5-10mil range, EAGLE can go as fine as 2mils. The
    manual states that for the follow-me autorouter the working grid IS the
    routing grid, so set your working grid to something in the 5-10 mil range.
    As a final note you can't manually add a via when using the follow-me
    router, the autorouter automatically calculates the via locations. If
    you want to manually lay down vias then you need to manually route the
    specific trace.
    hth,
    Jorge Garcia
    P.S Like Morten said don't mind Olin, he can be a little cranky
    sometimes. You'll find that most of the members of the forum including
    Olin are more than happy to help, and the forum is very active.
    >> unfriendly tone.
    You were asking how to do something irresponsible.  Not wanting to "create"
    >> way that the artwork is not violating any rules (i.e. not causing any DRC
    >> errors).
    already mentioned?
    result I want.
    /Daniel
    unfriendly tone.
    Quote:
    after I setup the clearance rules from the PCB manufacturer
    But that IS setting up the DRC.
    errors).
    already mentioned?
    Daniel nilsson <no-mail@nowhere.org> wrote:
    Since this was my first post to the forum I'm surprised by this unfriendly tone.
    Dont mind Olin. He has a long history of harshness to people that didnt
    rtfm word by word.
    On 03/08/2011 07:42 PM, Olin Lathrop wrote:
    Daniel Nilsson wrote on Mon, 07 March 2011 14:38
    That's really silly, downright irresponsible if you design boards for
    anyone else.
    unfriendly tone. I think you actuallt misunderstood my question, after I
    setup the clearance rules from the PCB manufacturer I want to use the
    follow-me router when doing manual routing in such a way that the
    artwork is not violating any rules (i.e. not causing any DRC errors).
    This is achieved with the follow-me router since it doesn't allow the
    artwork to cause DRCs errors, this is what I want by I'm looking for
    good settings for the follow-me router. The default rules have cost
    associated with all kinds of things such as steps and changing
    directions. It's not obvious which mix of costs and routing grid works
    best here.
    Quote:
    >> The follow-me router seems to be a good choice for what I'd like to do,
    >> but I have not been able to figure out good settings that will allow me
    >> to lay out the traces the way I want them but only use the follow-me
    >> functionality in order to be able to "hug" other traces or route as close
    >> example.
    Did you even look at the router settings?  There is such a thing as a
    "hugging" parameter.
    Yes of course, along with the manual and the tutorial. I turned to this
    forum for some best practice since this wasn't covered in any of these
    documents.
    anyone else.
    DRC is a important part of the board design process.  Especially when
    manually routing, you want something that verifies you didn't put two
    tracks too close together, copper too close to the board edge, maybe even
    accidentally have two tracks cross, etc.
    Also, you don't create a DRC.  There are always some DRC settings.  The
    only question is whether they match your desired design rules or not.  Some
    of these DRC settings aren't just for error checking either, they effect
    the resulting copper.  Examples are thermals, minimum annulus, and lots of
    others.  You are using some DRC settings all the time, whether you
    explicitly set them or not.
    example.
