EAGLE User Chat (English) Milling a No Copper Board
  • Views 441 views
Dear Experts,
All of the board I have developed over the last several years have been
simple rectangular or round boards defined by the Dimension Layer (20).  I
have a new client that wants several boards developed that ALL include
milled slots, and other odd shapes, both as cutouts in the outer edges, and
as cutouts in the interior of the boards.  I have several questions
regarding the development of these boards:
1) Do I use Polygons in the Milling Layer (45) for all of my
non-outside-dimension CNC operations?
2) If so, what "width" do I use?
3) How do I develop a CAM file for Layer 45 that a PC board house can use?
Thanks for your assistance.
Thomas W. Gustin
GUSTECH
Electronic Engineering Services
3760 Engle Mill Road
Xenia, OH 45385-9719
gustech@erinet.com
www.gustech.biz
    On 4/24/2011 10:45 AM, Mike Malherbe wrote:
    On 4/23/2011 12:11 PM, Thomas W. Gustin wrote:
    >> Dear Experts,
    >> edges, and
    >> use?
    >> Regards,
    Hello Thomas,
    I'll start the ball rolling and let the experts clean-up the mess. Ive
    used a number of methods from a series of closely spaced drill holes to
    drawing the router cutout using "WIRE" and "ARC" in the Milling Layer
    (Outline Layer can also work). Never tried Polygons in the Milling Layer
    but I suspect it will work as well, the people that fab the PCBs are
    experts at interpreting what we need. If you use WIRE or OUTLINE it is
    more reliable to use 0,2mm thickness. Sometimes 0 width can generate
    questions depending on the service used. You can designate the Milling
    Layer by changing an unused layer in the CAM. Rename the Section to
    Milling and rename the File extension to .mll or something similar, turn
    on only the Milling Layer then process the CAM job. Use a Gerber viewer
    to check your files and include a .txt file when you send the Gerbers to
    define .mll layer. Your board house may have a preferred bit size for
    slots so you will need to contact them. I use 1mm as a minimum.
    Best Regards,
    Mike
    I would not use polygons for the milling layer, they are converted into
    a series of tracks in the Gerbers, I would just draw the outlines.
    having just been burned by a board house not properly figuring the tool
    width in an outline ( they were sure it was good enough, they were
    wrong), I would use a width of zero or super small to hopefully make
    someone think and ask a question.
    bottom line, it's between you and the board house how you want it done.
    assume nothing is my advice, they can tell you what size router bits
    they will use and much more...
    Dear Experts,
    Hello Thomas,
    Layer but I suspect it will work as well, the people that fab the PCBs
    are experts at interpreting what we need.  If you use WIRE or OUTLINE it
    is more reliable to use 0,2mm thickness.  Sometimes 0 width can generate
    Best Regards,
    Mike
