EAGLE User Chat (English) Options for someone who needs a 120mm PCB
  • Views 597 views
Hi. I am an Eagle user who has done a few open source PCBs and now wants to
work with arcade hardware that uses a 56 way edge connector. The PCB needs
to be 120mm wide to accommodate this, and I want to do schematic and PCB in
Eagle because I am familiar with it.
Eagle Lite only goes up to 100mm per board and the Standard version is too
expensive, especially when some of the boards will be open source. I asked
and apparently you can't take a schematic drawn in the Freeware or Lite
version and use it to create a PCB in the Standard version, which is a
shame because I might just be able to stretch to getting the Standard PCB
module on its own.
Is that correct? Is there any other option for creating a board of this
size? I don't want to learn another CAD package if possible but might have
to image
    In the end I gave up. I will get Eagle Lite and just use Kicad for the one
    simple PCB I need that is bigger than Eagle allows.
    On second thoughts maybe the OS license is not that useful... The problem
    is that the kind of gaming hardware I make is desirable to people who are
    not engineers and so they always pester me to buy the boards.
    I wouldn't mind just giving them away at cost price, but my time is not
    free and I made that mistake before. Realistically there has to be some
    compensation for my time or I have to get someone else to do assembly and
    shipping, and obviously they want to be paid. Either that or just tell
    people I'm not doing them and they are for personal use only.
    One other potential issue is that open source hardware can be
    commercialised by anyone. In other words if someone sees the design and
    wants to make and sell their own boards then there isn't anything I can do
    to stop them, and it would seem to be a legally grey area because I would
    not be breaking my license agreement but that is clearly not what Cadsoft
    intended either.
    The hobby PCB fab houses often do that, e.g. you order 10 and they make 20
    and sell the spares via their own web site. I'm happy with it but I'm not
    sure Cadsoft would be.
    Hi Jorge,
    Thanks for that tip, it sorts out my problem nicely! All the arcade stuff
    is open source, and presumably there is no problem with one person having
    both an open source license and a Lite license for when I need to do
    (smaller) commercial boards. I will email Cadsoft to check of course!
    Can I install both versions at the same time too, or will I have to run one
    in a VM? It looks like the config file would be shared but as long as each
    has its own directory they should operate independently.
    module on its own.
    to image
    Hi Mojo,
    If you intend to make open source hardware, then you would qualify for
    the Non-Profit License which is a full-fledged standard version but for
    only $125.00 instead of the usual $747.00 for a commercial standard.
    The only condition on the Non-Profit is that it can't be used for
    commercial purposes. I know that should be understood but it's good to
    be explicit with legal mumbo jumbo.
    hth,
    Jorge Garcia
    just built two PCB's
