EAGLE User Chat (English) NNTP file size
  • Subscribers 187 subscribers
  • Views 420 views
NNTP file size
James Morrison wrote in eagle.support.eng
FYI, I've updated http://www.eaglecentral.ca/forums/ to allow up to 5
attachments and reduced the max size allowed to 50KB to match the nntp
server.  Sometimes one picture isn't just enough to explain and with
the small limit this should be good I think.
Thanks for increasing the number of attachments James.
Continuing this off subject discussion:
I suspect the following. Can anyone confirm if this is correct?
The file maximum file size accepted by nntp is 50K (nominal) but this is the
total message size limit so if attachments are included, the attachment size
must be under 50K so the entire wrapped message is under 50kB
I have seen a message posted at EagleCentral with an attachment of around
43kB and the message did not appear at nntp.
Warren
