EAGLE User Chat (English) Multi-line Text for Value
  • Replies 8 replies
  • Subscribers 189 subscribers
  • Views 2677 views
Is there anyway to make text fields (like Value) to use multiple lines?
We occasionally have long descriptions, and Eagle prints them in one
lone line.  I have tried the standard  and \n, but no luck.
    autodeskguest over 9 years ago in reply to michel_c12
    On 4/26/2017 5:21 AM, Michel Carbone wrote:
    Hello Jorge
    Yes I agree multi-line for value field of parts does not make sense in my point of view also.
    I join this question because unlike the TEXT fields that support multi-line, all other text variable such as NAME, VALUE, ATTRIBUTES does not support multi-line neither special character like \t, \n.
    In fact I am trying to display on the schematic as a table the values of net classes (UL_CLASS) for minimum drill, width and clearances between net classes. So, as they values are not available as special field (I mean like special field like >DRAWING_NAME) I am writing an ULP file to set attributes values of a symbol element containing current values used in the schematic and layout.
    It would be very more easy to set an attribute, like for example >NET_CLASS_NAMES with all names of net classes separated by a carriage return that setting as many attributes field as they are net class names. Moreover, the number of net classes is unknown at the beginning so I will need to handle as many symbol as there could have net classes in the layout and handle also the case where the ability to define different net class clearances between classes is not used...
    Best regards,
    Michel Carbone
    https://www.element14.com/community/message/221297
    Hello Michel,
    I hope you're doing well.I see the issue, check out the
    drillegend-stack.ulp that comes with EAGLE it has a solution for
    creating tables. You might be able to just copy that code and modify it
    for your application.
    The cmd-change-class.ulp that comes with EAGLE can give you some insight
    into how to process the netclasses using the ULP.
    Best Regards,
    Jorge Garcia
    Autodesk Support
    We have a new forum here <http://forums.autodesk.com>
  • michel_c12
    michel_c12 over 9 years ago in reply to autodeskguest
    Hello Jorge
    Best regards,
    Michel Carbone
    On 4/24/2017 6:49 AM, Michel Carbone wrote:
    Yes my question was for fields like value of parts and also for attributes values
    Michel
    https://www.element14.com/community/message/221191
    Hi Michel,
    This is still not possible, not even in the new Autodesk EAGLE. It's one
    of those small things that has been overshadowed by more involved features.
    Additionally, I don't know if this makes sense for value. When
    generating a BOM usually you get some form of spreadsheet and having
    multiple lines might create issues there.
    Could you describe what you are trying to do? That can help guide the
    discussion towards a solution that gets you the result you want.
    Best Regards,
    Jorge Garcia
  • michel_c12
    Michel
    autodeskguest over 9 years ago in reply to dukepro
    On 21.04.2017 15:41, Chuck Huber wrote:
    On 04/20/2017 08:58 AM, Michel Carbone wrote:
    Is that still not possible in version 7.7?
    It's possible.  Run the TEXT command (or click the icon) to open the
    dialog box.  As you enter the text, use Shift-Enter to get to the next
    line.  Just below the text area, you'll see the hint.
    HTH,
         - Chuck
    He means for the value of a part. And AFAIK its not possible.
  • dukepro
    dukepro over 9 years ago in reply to michel_c12
    HTH,
        - Chuck
  • michel_c12
    michel_c12 over 9 years ago in reply to Richard_H
    Thanks in advance
    Michel
  • Richard_H
    Richard_H over 15 years ago
    Am 11.07.2011 02:41, schrieb Marvin Dawson:
    lone line. I have tried the standard <ctrl>-<enter> and \n, but no luck.
    I am sorry, but this is currently not possible.
    Richard Hammerl
