EAGLE User Chat (English) Move from DXF layer into TOP layer.
  • Views 787 views
I have some polygons on DXF layer that I need to
move to TOP layer...
I can't find a way to do it.
The  cmd-change-swap-layer.ulp   does not change
from drawing layer to copper layer
and the   copy-layer-to-any-layer.ulp   does not
do anything that I can understand.
Please help.
Many thanks.
Luis C.
    e14 Contributor over 15 years ago in reply to Richard_H
    On 7/25/2011 2:15 PM, Richard Hammerl wrote:
    Am 25.07.2011 14:22, schrieb lc:
    >> On 7/25/2011 12:22 PM, Richard Hammerl wrote:
    >>> Am 23.07.2011 00:12, schrieb lc:
    >>>> Hello,
    >>>> Please help.
    >>>> Many thanks.
    >>>> Luis C.
    >>> copy-layer-to-any-layer.ulp should work.
    >>> What is the layer the polygon is in now?
    >>> Is there an error message when running the ULP?
    >> No, copy-layer-to-any-layer.ulp only copies
    >> between copper layers the same...
    >> The point is copying from a drawing layer to a copper
    >> layer... the polygons are at the DXF layer.
    >> From all comments I've been receiving it seems
    >> to be impossible.
    >> I'll have to draw he thing by hand on the top layer.
    >> tks. anyway.
    >> l.c.
    This is exactly the reason why copy-layer-to-any-layer.ulp was
    made. It is possible to copy something from a drawing layer into
    a copper layer. I just tried it with a polygon from layer 29. I
    could copy it into layer 1.
    The reason why EAGLE can't handle this internal is that layers 1
    to 16 can belong to signals and have signal names and objects
    in drawing layers don't have names. So there is a restriction
    which allows to put an object from one signal layer into another
    signal layer, but not into a drawing layer and vice veras.
    The ULP simply drops the signal name or creates a signal name,
    depending on situation.
    Tks for info.
    lc.
  • Richard_H
    Richard_H over 15 years ago in reply to e14 Contributor
    >>> Hello,
    >>> Please help.
    >>> Many thanks.
    >>> Luis C.
    to be impossible.
    tks. anyway.
    l.c.
    Richard Hammerl
    Yeap, you are right. You can change polygon layer from any NO_SIGNAL layer
    to any NO_SIGNAL layer (dimension, dxf, etc...), but you can not change
    polygon layer from NO_SIGNAL layer to SIGNAL layer (top, bottom). It sounds
    you found a bug image
    Anyway, I do not know how you imported your polygons to dxf layer. In my
    case, when I need to import dxf data, I follow this procedure:
    s1) generate dxf file with any cad software,
    s2) translate the dxf file to an eagle script file (using an external tool
    like dxf2scr.exe),
    s3 run the previously created script file from eagle,
    s4) lines and arcs are now in your board.
    If you usually import your dxf data with the same procedure, you could
    simply edit the generated script file and change the line containing the
    Layer name to the one you want (Layer top I guess).
    Cheers.
    Stephane
    >> Hello,
    >> Please help.
    >> Many thanks.
    >> Luis C.
    to be impossible.
    tks. anyway.
    l.c.
  • Richard_H
    Please help.
    Many thanks.
    Luis C.
    Richard Hammerl
