EAGLE User Chat (English) Can "export" automatically overwrite an existing file?
  • Views 922 views
Good afternoon,
I'm executing a script generated by a ULP that exports all sheets of a
schematic to .png files.  The script command being executed is:
   export image filename.png;
If filename.png exists, the script stops and asks if it's okay to
overwrite.  Is there a way I can force export to overwrite without
asking the user?  I tried using "remove" to delete the file first, and
it asks the user for confirmation.
    - Chuck
  • jeromeabcpcb
    jeromeabcpcb over 15 years ago in reply to e14 Contributor
    "Andreas Weidner"  a écrit dans le message de groupe de discussion :
    j2aoqk$l46$1@cheetah.cadsoft.de...
    Am 14.08.2011 00:51, schrieb Chuck Huber:
    asking the user?
    set confirm yes;
    set confirm off;
    The "SET Confirm" is used to tell EAGLE to automatically confirm
    questions with the desired answer (in this case, answer 'overwrite the
    file?' with 'Yes'). Should be used only sparingly, and be switched off
    immediately after use - otherwise, other dialogs might also get an
    unwanted automatic answer.
    Andreas Weidner
    Nice function but only available on the latest 5.11 release.
    Jerome
    asking the user?
    set confirm yes;
    set confirm off;
    Andreas Weidner
    On 08/13/2011 06:51 PM, Chuck Huber wrote:
    Good afternoon,
    asking the user?
    I found a work around... I have to keep a list of all the files that
    will be overwritten, and do
        string FileNames[];
        ... // Populate the FileNames array
        system("rm " + strjoin(FileNames, ' '));
    just prior to exiting the ulp.
    Maybe there's an argument to the export script command that will do this
    for me.
        - Chuck
