EAGLE User Chat (English) Executing commands from the command line that contain spaces
  • Subscribers 189 subscribers
  • Views 549 views
After an exhaustive search through the manual and help files, I'm still
stumped.
I'm trying to execute a command that contains a space:
    > eagle -C "run panelize;" myboard.brd
Eagle is interpreting the space inside the command as a separator
causing a list of ulp's to be presenting and opening the board
"panelize;.brd".
I even tried the example in Help->Command Line Options:
   eagle -C "window (1 1) (2 2);" myboard.brd
which doesn't work either.  In this case, it opens "(1.brd", again
interpreting the embedded space as a command line separator.  It's as if
eagle is concatenating all of the argv[]'s then parsing them as a single
string, disregarding what the shell has provided.
I have also tried single quotes, and backslashes preceding the spaces to
no avail.
Eagle 5.11.0
Linux kernel 2.6.37 on x86_64
Bash version: 4.1.10
Any ideas as to why
    - Chuck
    e14 Contributor over 15 years ago in reply to kcadsoft
    On 08/16/2011 10:39 AM, Klaus Schmidinger wrote:
    >> stumped.
    >> "panelize;.brd".
    >> no avail.
    >> Eagle 5.11.0
    Works just fine here (also on Linux).
    Maybe your shell doesn't handle double quotes correctly?
    What does
      echo "a         b"
    (several blanks between a and b) give you? Is it
      a         b
    or
      a b
    I get the spaces.  It's the standard Bourne-again shell - "bash" - that
    ships with most distributions.  Recall that it doesn't work with single
    quotes, nor with escaped spaces.
    I found it.  /usr/local/bin/eagle is a shell script that launches eagle
    from it's installed tree.  It's the first "eagle" in $PATH and amounts to:
        exec /opt/eagle-5.11.0/bin/eagle $*
    It should be:
        exec /opt/eagle-5.11.0/bin/eagle "$@"
    Maybe this revelation, found buried deep within the man pages, will help
    someone else.
    Enjoy,
        - Chuck
  • kcadsoft
    kcadsoft over 15 years ago
    stumped.
    "panelize;.brd".
    no avail.
    Eagle 5.11.0
    What does
       echo "a         b"
       a         b
    or
       a b
    Klaus Schmidinger
    Pleidolfweg 15                          Email:   kls@cadsoft.de
