EAGLE User Chat (English) join two boards?
  • Views 311 views
join two boards?
How to join two boards?
I'm have two problems:
Join two boards in one board.
Duplicate one board in one file(two boards identicals in one board). no need make two conections.
My english is bad. (Brazilian)
I'm learning ;D
Help me please...
    I'm learning ;D
    Help me please...
    Hi Lucas,
    For your first issue, if I understand you, you want to bring two
    separate board files into one board file.
    This can be done by opening the source board, turning on all layers,
    group select all items and cut. (Cut = Copy)
    Next in the same control panel open the destination board and paste the
    contents into the board. You will of course not be consistent any more
    unless you do the same with the schematic also. Identical reference
    designators may be a also problem.
    For your second issue, it sounds like the panelize ULP would help you.
    If you just copy and paste Eagle will assign new reference designators
    to the pasted components. Panelize places the reference designators on
    new layers which you output to cam instead of the regular layers.
      This I usually do with a copy of the board as consistency is lost.
    Of course if you want new reference designators cut and paste should
    work for you.
    Your English is pretty good, Keep at it.
    Better than my Portuguese I'm sure.
    HTH
