EAGLE User Chat (English) Eagle CAD on CentOS 6?
  • Subscribers 189 subscribers
  • Views 476 views
  • eagle
  • 64bit
  • install
  • linux
lf4
lf4 over 14 years ago
I tried installing Eagle CAD on my CentOS6 system and keep getting this error where it cant find the library libxrandr.so.2 even though it's installed. Does Eagle CAD not work on 64bit systems? Has anyone been able to successfully install it on Centos?
LF4
  • lf4
    lf4 over 14 years ago in reply to fustiniadmin
    Yeah I figured out all the dependencies it was a little annoying that it didn't check for each one and then list them all I had to try to install multiple times to get a new error. For those that are trying to run eagle on CentOS 6 64 bit install all these libraries.
    sudo yum install libXrandr.i686 libXcursor.i686 libfontenc.i686 expat.i686 fontconfig.i686 libpng.i686 libjpeg.i686 libgcc.i686 libstdc++.i686
    LF4
  • fustiniadmin
    fustiniadmin over 14 years ago
    LF4
    I am using 64-bit Ubuntu 11.04 and can run Eagle 5.11.0 ok.  It is a
    32-bit binary so I had to add the packages related to 32-bit
    compatibility.  This is /usr/lib32 on my system.
    I'm sure the details for 32-bit libs are a bit different for CentOS/RHEL
    but hopefully you can get the 32-bit version of that lib from some repo
    or site.  (Although I am right now having trouble with locating the
    newer 32-bit libs for my system to run the v6 Beta, v5.91.1)
    Cheers,
    Drew
