EAGLE User Chat (English) How to import a .STEP cad file to Eagle
  • Subscribers 192 subscribers
  • Views 5825 views
  • step
  • cad
  • file
hazzer
hazzer over 14 years ago
I was wondering if anyone could help / point me to a description of how to take a STEP file (a cad drawing) of a ALPS switch and import into Eagle as a libary item?
(or should I just start from the begining and draw a new item in Eagle?)
The item Im trying to use is push switch from ALPS
http://www.alps.com/WebObjects/catalog.woa/E/HTML/Switch/Push/SPUJ/SPUJ193700.shtml
Regards
Hazzer
  • firefox-lunarchode
    firefox-lunarchode over 8 years ago in reply to jeromeabcpcb
    Thank you for some info provided in this post.
    From these I was able to import the STEP generated file of my component in Sketchup and set colors on the component part, now mt trouble is how to import this 3D model inside my library as 3D footprint?
    Thank
    Fabio
  • rpcomms
    rpcomms over 9 years ago
    God that's way too long winded.
    OK easy peasy,take STEP file view in Mechanical CAD software (RS Design Spark)  top view,make sure DXF setting 1:1 scale true font
    Export OUTPUT DXF format
    Go into PCB CAD software edit component (assume you made symbols and pads),import layer as shape.
    Position in correct place,I use the solder pins from DXF to align then remove 99% pins pads by turning PCB layers off, success rate 99%
    check scaling set correct when importing DXF files into PCB cad.
    I do it this way for loads of different shapes,even Icons.
    Running Easy PC CAD V19 here,same as RS Design Spark-Eagle should be able to do same thing,but not tried but found a egale DXF Import ULP
    here
    https://github.com/erikwilson/import-dxf
    Rob
  • hazzer
    hazzer over 14 years ago in reply to jeromeabcpcb
    Cheers Jerome
    I'll go over the videos 2night.
    Harry
  • jeromeabcpcb
    jeromeabcpcb over 14 years ago in reply to e14 Contributor
    "Morten Leikvoll"  a écrit dans le message de groupe de discussion :
    589724597342302077.993435mleilvol-yahoo.nospam@news.cadsoft.de...
    The step model is a 3d format for viewing the components physicalities. It
    does non contain soldering information.
    But it would be nice is a future version could actually use it and render
    it for 3d collision drc. It could also be used to check your footprint, and
    if I dream further it could be used to auto create the footprint.
    I suspect that neither is not going to happen in many years, if ever.
    Step files are not very useful for a footprint where you need mainly proper
    outline, pads and drills.
    However, if you have time, here is a way to check that your footprint will
    fit the Switch :
    - make your own library package for the switch, based on the datasheet.
    - see http://eagleup.wordpress.com/how-to-model/#import_step to convert your
    step model into a skp file (can be quite long, see the video)
    - install the export/import plugins by following the tutorial
    http://eagleup.wordpress.com/installation-and-setup/
    - then export your board and import it into Sketchup. If you have all the
    steps correct you should see your board and the switch on it.
    I use this process with every new mechanical part, as usually their
    datasheet is not very precise for our E-CAD use image
    You can also see eventual collisions with your enclosure, with other
    components ...
    Check this video for a real world exemple of project modeled in a couple of
    days :
    http://www.youtube.com/watch?feature=player_embedded&v=uC9YPETKAYg
    Jerome
    into Eagle as a libary item? (or should I just start from the
    Regards
    Hazzer
    Creatiing your own library part is the way to go. Besides, I suspect the
    pad information would not be in the STEP file.
    news.cadsoft.de
