Im looking for a male DVI-D (dual link) right angle connector for pcb mount.
This is not very typical, as the females usually go on pcb and males on
cables.
Does anyone know of a manufacturer?
cables.
Am 09.11.2011 14:26, schrieb Morten Leikvoll:
"Joern Paschedag"<jpaschedag@t-online.de> wrote in message
news:j9dgnu$a0l$1@cheetah.cadsoft.de...
>> Am 08.11.2011 22:38, schrieb Morten Leikvoll:
>>> "Warren Brayshaw"<warrenbrayshaw@paradise.net.nz> wrote:
>>>>> mount. This is not very typical, as the females usually go on pcb and
>>>>> males on cables.
>>>> http://www.alibaba.com/product-gs/496931865/DVI_24_5_Male_Connector_PCB.html
>>> Thanks. Questionable quality, but may work.
>> http://www.hdequipment.eu/DVI-connector-24%2B5-Right-angle-PCB-3JL-series.html
>> maybe it helps
Thanks, but I'm afraid this is the female connector (receptable), but they
seem to have straight connectors (plug) used for cabling. I guess I can work
with that if I have to.
It was more ment to give you some alternate addresses, and according to
them they have angeled male DVI's.
Joern Paschedag
Hi Morton,
I don't know how many pieces you need.But I found that you are from Norway. You might contact farnell in Norway through their website http://no.farnell.com and ask technical support for Molex part no 0743232033 and ask if they can quote for you. Otherwise you can look at molex site if this is what you need http://www.molex.com/webdocs/datasheets/pdf/en-us/0743232033_IO_CONNECTORS.pdf
"Joern Paschedag" <jpaschedag@t-online.de> wrote in message
>>>> males on cables.
maybe it helps
>>> males on cables.
maybe it helps
Joern Paschedag
>>> pcb mount. This is not very typical, as the females usually go on
>>> pcb and males on cables.
It was only a quick Google. I too felt I would have preferred to have a more
reputable source but I could not find one. I have the impression that what
is available are old designs and did not like the way the part interfaced
with the PCB.
All the best
Warren
news.cadsoft.de
with the PCB.
All the best
Warren
news.cadsoft.de
>> males on cables.
males on cables.
news.cadsoft.de
